- To: coq-club AT pauillac.inria.fr
- Subject: [Coq-Club] Re: Dealing with equivalence classes
- Date: Thu, 07 Feb 2008 23:38:34 -0800
- Cancel-lock: sha1:F1VDiER/9nP9kmuOJuKxh7iypIg=
- Organization: Myself
Edsko de Vries
<devriese AT cs.tcd.ie>
writes:
> Inductive typeof : env -> trm -> typ -> Prop :=
> | forall (G : env) (f x : trm) (a b : typ),
> typeof G f (fn a b) ->
> typeof G x a ->
> typeof G (trm_app f x) b.
> What I might want to prove (as a simple test) is that the type of 'f x'
> is 'Int:True'. However, (so far at least), this proof will fail, because
> the type in the domain of f (Int:True) does not match the type of x
> (Int:Or True True).
I think you'll need to declare an equivalence relation on typ such
that two values of typ are equivalent if they are built from
equivalent components.
- a
- [Coq-Club] Dealing with equivalence classes, Edsko de Vries
- [Coq-Club] Re: Dealing with equivalence classes,
Adam Megacz
- Re: [Coq-Club] Re: Dealing with equivalence classes,
Edsko de Vries
- Re: [Coq-Club] Re: Dealing with equivalence classes, Arnaud Spiwack
- [Coq-Club] Re: Dealing with equivalence classes, Adam Megacz
- Re: [Coq-Club] Re: Dealing with equivalence classes, Edsko de Vries
Edsko de Vries
Adam Megacz
