- To: coq-club AT pauillac.inria.fr
- Subject: [Coq-Club] Rewritinig *one* occurrence using setoid rewriting
- Date: Thu, 7 Feb 2008 13:08:23 +0000
Hi,
Suppose I have something like
Lemma foo : equiv a'' (or a'' a')
Say I want to rewrite the first occurrence of a'' with (or a'' false).
When I do
rewrite <- (or_id a'').
both occurrences of a'' are replaced (following Adam's suggestion I've
setup the setoid stuff for my boolean expressions). If I do
pattern a'' at 1 ; rewrite <- (or_id a'')
it complains about the argument being in a covariant position.
replace a'' at 1 with (or a'' false)
gives me a subgoal
a'' = or a'' false
which is too strong (they are merely equivalent, not equal), and
setoid_replace does not seem to have an 'at 1' option.
Is there a way to apply the setoid rewriting to a particular occurrence
only?
Thanks,
Edsko
- [Coq-Club] Rewritinig *one* occurrence using setoid rewriting, Edsko de Vries
- Re: [Coq-Club] Rewritinig *one* occurrence using setoid rewriting,
Damien Pous
Edsko de Vries
Stephane Glondu
Edsko de Vries
- Re: [Coq-Club] Rewritinig *one* occurrence using setoid rewriting, Vincent Aravantinos
- Re: [Coq-Club] Rewritinig *one* occurrence using setoid rewriting, Brian Aydemir
Edsko de Vries
Stephane Glondu
Edsko de Vries
Damien Pous
