- To: Damien Pous <Damien.Pous AT ens-lyon.fr>
- Cc: coq-club AT pauillac.inria.fr
- Subject: Re: [Coq-Club] Rewritinig *one* occurrence using setoid rewriting
- Date: Fri, 8 Feb 2008 15:11:32 +0000
On Fri, Feb 08, 2008 at 09:21:43AM -0500, Damien Pous wrote:
> Hi,
> I had the same problem two months ago, you can use the set tactic in
> order to isolate the occurrence of the term you want to rewrite:
> Require Import Setoid.
> Variable meq: nat -> nat -> Prop.
> Axiom meq_refl: reflexive _ meq.
> Axiom meq_trans: transitive _ meq.
> Axiom meq_sym: symmetric _ meq.
> Add Relation nat meq
> reflexivity proved by meq_refl
> symmetry proved by meq_sym
> transitivity proved by meq_trans as meq_Relation.
> Variables a b c: nat.
> Axiom ab: meq a (a+b).
> Goal meq a (a+c).
> set (x := a) in |- * at -1.
> rewrite ab.
That's a nice trick! I tried to abstract it to a tactic:
Ltac rewrite_first t t' :=
let H := fresh in
set (H := t) in |- * at -1 ;
rewrite t' ;
subst H.
which can then be used as
Goal meq a (a+c).
rewrite_first a ab.
which is reasonably nice (we should introduce some custom notation,
perhaps). It would be nicer if we should pass in a position, but
unfortunately if we define
Ltac rewrite_at t t' pos :=
let H := fresh in
set (H := t) in |- * at pos ;
rewrite t' ;
subst H.
then
rewrite_at a ab 1.
gives
User error: Ltac variable pos is bound to a term
which cannot be coerced to an integer
and
rewrite_at a ab -1.
even gives a syntax error at the '-'
Syntax error: '.' or '...' expected after [tactic:tactic] (in
[subgoal_command])
I don't know if that can be solved.
Thanks,
Edsko
- [Coq-Club] Rewritinig *one* occurrence using setoid rewriting, Edsko de Vries
- Re: [Coq-Club] Rewritinig *one* occurrence using setoid rewriting,
Damien Pous
- Re: [Coq-Club] Rewritinig *one* occurrence using setoid rewriting, Edsko de Vries
Stephane Glondu
Edsko de Vries
- Re: [Coq-Club] Rewritinig *one* occurrence using setoid rewriting, Vincent Aravantinos
- Re: [Coq-Club] Rewritinig *one* occurrence using setoid rewriting, Brian Aydemir
Edsko de Vries
Stephane Glondu
Damien Pous
