- To: Edsko de Vries <devriese AT cs.tcd.ie>
- Cc: coq-club AT pauillac.inria.fr
- Subject: Re: [Coq-Club] Rewritinig *one* occurrence using setoid rewriting
- Date: Fri, 15 Feb 2008 10:36:03 -0500
On Feb 15, 2008, at 10:26 AM, Edsko de Vries wrote:
On Fri, Feb 15, 2008 at 04:09:40PM +0100, Stephane Glondu wrote:
What about:
Tactic Notation "rewrite_at" constr(t) constr(t') integer(pos) :=
let H := fresh in
set (H := t) in |- * at pos ;
rewrite t' ;
subst H.
Perfect! Thanks for that. Is that syntax (constr, integer) documented anywhere? I can't find it in the chapter on tactics in the Coq manual.
Take a look at Section 11.4 of the reference manual (at least for Coq 8.1). The documentation for Tactic Notation is in there with the documentation for Notation.
Cheers,
Brian
- [Coq-Club] Rewritinig *one* occurrence using setoid rewriting, Edsko de Vries
- Re: [Coq-Club] Rewritinig *one* occurrence using setoid rewriting,
Damien Pous
Edsko de Vries
Stephane Glondu
Edsko de Vries
- Re: [Coq-Club] Rewritinig *one* occurrence using setoid rewriting, Vincent Aravantinos
- Re: [Coq-Club] Rewritinig *one* occurrence using setoid rewriting, Brian Aydemir
Edsko de Vries
Stephane Glondu
Edsko de Vries
Damien Pous
