- To: Stephane Glondu <steph AT glondu.net>
- Cc: coq-club AT pauillac.inria.fr
- Subject: Re: [Coq-Club] Rewritinig *one* occurrence using setoid rewriting
- Date: Fri, 15 Feb 2008 15:26:58 +0000
On Fri, Feb 15, 2008 at 04:09:40PM +0100, Stephane Glondu wrote:
> Edsko de Vries a écrit :
> >which is reasonably nice (we should introduce some custom notation,
> >perhaps). It would be nicer if we should pass in a position, but
> >unfortunately if we define
> > Ltac rewrite_at t t' pos :=
> > let H := fresh in
> > set (H := t) in |- * at pos ;
> > rewrite t' ;
> > subst H.
> >then
> > rewrite_at a ab 1.
> >gives
> > User error: Ltac variable pos is bound to a term
> > which cannot be coerced to an integer
> What about:
> Tactic Notation "rewrite_at" constr(t) constr(t') integer(pos) :=
> let H := fresh in
> rewrite t' ;
> subst H.
Perfect! Thanks for that. Is that syntax (constr, integer) documented
anywhere? I can't find it in the chapter on tactics in the Coq manual.
Edkso
- [Coq-Club] Rewritinig *one* occurrence using setoid rewriting, Edsko de Vries
- Re: [Coq-Club] Rewritinig *one* occurrence using setoid rewriting,
Damien Pous
Edsko de Vries
Stephane Glondu
- Re: [Coq-Club] Rewritinig *one* occurrence using setoid rewriting, Edsko de Vries
- Re: [Coq-Club] Rewritinig *one* occurrence using setoid rewriting, Vincent Aravantinos
- Re: [Coq-Club] Rewritinig *one* occurrence using setoid rewriting, Brian Aydemir
Stephane Glondu
Edsko de Vries
Damien Pous
