- Cc: coq-club AT pauillac.inria.fr
- Subject: Re: [Coq-Club] Managing memory from Coq - Correction
- Date: Thu, 6 Mar 2008 17:00:37 +0100 (CET)
On Thu, 6 Mar 2008, Lionel Elie Mamane wrote:
> On Thu, Mar 06, 2008 at 04:23:05PM +0100, Freek Wiedijk wrote:
> >> but if you refrain from any sort of "Show Proof" and you have a
> >> sizeable amount of swap activated, your OS should do about that
> >> automatically...
> > Won't the garbage collector swap it in all the time?
> That's a very good point; you are probably right.
Well, it depends on the kind of garbage collector and memory model of the
ML system. For example, as far as I understand SML/NJ's stackless
stop-and-copy model, the virtual memory space is continously ploughed
through, yielding swap-ins all time. Poly/ML is much smarter in not
touching persistent areas. Coq uses Ocaml, so the experts on that system
should know.
Makarius
- [Coq-Club] Managing memory from Coq - Correction, marko
- Re: [Coq-Club] Managing memory from Coq - Correction,
Lionel Elie Mamane
- Message not available
Lionel Elie Mamane
- Re: [Coq-Club] Managing memory from Coq - Correction, Makarius
Lionel Elie Mamane
JAEGER, Eric (SGDN)
Frédéric Besson
Benjamin Gregoire
JAEGER, Eric (SGDN)
marko
- [Coq-Club] Big inductive proofs, Jean Goubault-Larrecq
- Re: [Coq-Club] Big inductive proofs, Roland Zumkeller
- Re: [Coq-Club] Big inductive proofs, Jean Goubault-Larrecq
- Re: [Coq-Club] Big inductive proofs, Eduardo Gimenez
marko
JAEGER, Eric (SGDN)
Benjamin Gregoire
Frédéric Besson
Lionel Elie Mamane
