- From: "JAEGER, Eric (SGDN)" <eric.jaeger AT sgdn.gouv.fr>
- To: "Lionel Elie Mamane" <lionel AT mamane.lu>, <marko AT ffri.hr>
- Cc: <coq-club AT pauillac.inria.fr>
- Subject: Re: [Coq-Club] Managing memory from Coq - Correction
- Date: Thu, 6 Mar 2008 17:20:27 +0100
In system I develop I have all the time lot of (un)prooved
subgoals. Proved subgoals are not interesting for me but unproved
are. I guess the Coq keep all of them in RAM until I proving the
main goal. Is it correct? I need to optimize the time of processing.
Is it possible to store unproved subgoals on hard disk and then
erase them from memory? Later I will take it from disk as needed.
I don't think Coq has an explicit mechanism for that, but if you
refrain from any sort of "Show Proof" and you have a sizeable amount
of swap activated, your OS should do about that automatically... until
Qed time.
Preferring the computer computing rather than me thinking, I've developped
this very stupid proof, with as a stunning result the correctness of the
addition of two bytes. I guess this illustrates the question about
optimizing space and time.
Generating 256 subgoals (breaking the proof at BP 1) takes 3-5 seconds on my
PC. I've never been patient enough the see the 65536 subgoals (breaking the
proof at BP 2) but this seems to be far more than 256*5 seconds, and my swap
has been expanded by more than 1GB. I cannot imagine ever being able to
compile the proof as provided. It may be possible to optimize the
definitions (yet I think e.g. that b7*2 is more efficient than 2*b7), but
this would not help regarding the generation of subgoals. Is there a way,
may be, to ask Coq to be more "lazy" when generating subgoals ?
Regards, Eric
Inductive bit:Set:= v0:bit | v1:bit.
Definition bit2nat(b:bit):nat:=match b with v0 => 0 | v1 => 1 end.
Coercion bit2nat:bit>->nat.
Definition comp1(b:bit):bit:=match b with v0 => v1 | v1 => v0 end.
Definition add11(b1 b2 b3:bit):=
match (b1,b2,b3) with (v0,v0,_) => (v0,b3) | (v1,v1,_) => (v1,b3) | _ =>
(b3,comp1 b3) end.
Inductive byte:Set:=bt:bit->bit->bit->bit->bit->bit->bit->bit->byte.
Definition byte2nat(b:byte):nat:=
match b with bt b7 b6 b5 b4 b3 b2 b1 b0 =>
(((((((b7*2+b6)*2+b5)*2+b4)*2+b3)*2+b2)*2+b1)*2+b0) end.
Coercion byte2nat:byte>->nat.
Definition add88(b1 b2:byte):=
match b1 with bt b17 b16 b15 b14 b13 b12 b11 b10 =>
match b2 with bt b27 b26 b25 b24 b23 b22 b21 b20 =>
match add11 b10 b20 v0 with (c0,b30) =>
match add11 b11 b21 c0 with (c1,b31) =>
match add11 b12 b22 c1 with (c2,b32) =>
match add11 b13 b23 c2 with (c3,b33) =>
match add11 b14 b24 c3 with (c4,b34) =>
match add11 b15 b25 c4 with (c5,b35) =>
match add11 b16 b26 c5 with (c6,b36) =>
match add11 b17 b27 c6 with (c7,b37) =>
(c7,bt b37 b36 b35 b34 b33 b32 b31 b30)
end end end end end end end end
end
end
Theorem add88_correct:forall (b1 b2:byte),
match (add88 b1 b2) with (c,b) => b1+b2=c*256+b
end.
Proof.
induction b1 as [b17 b16 b15 b14 b13 b12 b11 b10];
induction b10; induction b11; induction b12; induction b13;
induction b14; induction b15; induction b16; induction b17; (* BP 1 *)
induction b2 as [b27 b26 b25 b24 b23 b22 b21 b20];
induction b20; induction b21; induction b22; induction b23;
induction b24; induction b25; induction b26; induction b27; (* BP 2 *)
simpl; apply refl_equal.
Qed.
- [Coq-Club] Managing memory from Coq - Correction, marko
- Re: [Coq-Club] Managing memory from Coq - Correction,
Lionel Elie Mamane
- Message not available
- Re: [Coq-Club] Managing memory from Coq - Correction, Lionel Elie Mamane
- Re: [Coq-Club] Managing memory from Coq - Correction, JAEGER, Eric (SGDN)
Frédéric Besson
Benjamin Gregoire
JAEGER, Eric (SGDN)
marko
- [Coq-Club] Big inductive proofs, Jean Goubault-Larrecq
- Re: [Coq-Club] Big inductive proofs, Roland Zumkeller
- Re: [Coq-Club] Big inductive proofs, Jean Goubault-Larrecq
- Re: [Coq-Club] Big inductive proofs, Eduardo Gimenez
marko
JAEGER, Eric (SGDN)
Benjamin Gregoire
Frédéric Besson
Lionel Elie Mamane
