- To: Julien Forest <forest AT ensiie.fr>
- Cc: coq-club AT pauillac.inria.fr
- Subject: Re: [Coq-Club] functional induction and nested list's
- Date: Wed, 9 Apr 2008 16:47:50 +0200
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=cc:message-id:to:in-reply-to:content-type:content-transfer-encoding:mime-version:subject:date:references:x-mailer:from; b=U4eaqdDgRbMgpIHcVQXs+uc034HEewVx7Gv2igCoPJXlEMC241bmw5JM+EoF+Db6vbl0jzTwhd7thywoUrXU5+BTvWODvvCLvCFdb9Rvs0q5/GNt6AmXLVFkIEp+5O2LmdsQTxJGAy32k9UboMOUawsaCvzXt7myR3m3l67oHXY=
Dear Julien,
Thank you for the hint about inlining subst_mems! Is it discussed in a FAQ that I should have read?
I implemented your suggestion, and now my fixpoint is accepted, but on using Functional Scheme, I get:
"Anomaly: add_args : todo. Please report."
Is this the restriction you mentioned? I guess the only way to use functional induction without defining the (huge) induction principles by hand (which I've already done for the normal induction principles) is to remove nested occurrences of list etc in my datatypes (as illustrated in my example below). That'd be quite unfortunate :-(
cheers,
adriaan
ps: here's the relevant fragment from my script:
Fixpoint subst_tm (z : var) (u : tm) (e : tm) {struct e} : tm :=
match e with
| bvar i => bvar i
| fvar x => if x == z then u else (fvar x)
| sel e1 l => sel (subst_tm z u e1) l
| new T => new (subst_tp z u T)
end
with subst_tp (z : var) (u : tm) (e : tp) {struct e} : tp :=
let subst_mems := fix subst_mems (mems:list mem) {struct mems} :=
match mems with
| nil => nil
| cons m ms => cons (subst_mem z u m) (subst_mems ms)
end in
match e with
| tp_struct None mems => tp_struct None (subst_mems mems)
| tp_struct (Some self) mems => tp_struct (Some (subst_tp z u self)) (subst_mems mems)
end
with subst_mem (z : var) (u : tm) (e : mem) {struct e} : mem :=
match e with
| mtm l T None => mtm l (subst_tp z u T) None
| mtm l T (Some rhs) => mtm l (subst_tp z u T) (Some (subst_tm z u rhs))
end.
Functional Scheme subst_tm_ind := Induction for subst_tm Sort Prop
with subst_tp_ind := Induction for subst_tp Sort Prop
with subst_mem_ind := Induction for subst_mem Sort Prop.
On 09 Apr 2008, at 16:14, Julien Forest wrote:
Dear Adriaan,
On Wed, 9 Apr 2008 10:12:03 +0000 (UTC)
Adriaan Moors
<adriaan AT cs.kuleuven.be>
wrote:
Dear Club,
I'm trying to do functional induction on my substitution function. My current
definition uses List.map to define substitution on a list of members in terms
of substitution on a single member. This breaks the generation of the
induction principle, which I can live with. Thus, to be able to generate the
induction principle automatically, I simplified my definition to the
following, which still does not work:
Require Import List.
Inductive trm : Set :=
| new : typ -> trm
with typ : Set :=
| strct : list member -> typ
with member : Set :=
| membr : typ -> trm -> member.
Function subst_trm (e : trm) {struct e} : trm :=
match e with
| new T => new (subst_typ T)
end
with subst_typ (e : typ) {struct e} : typ :=
match e with
| strct mems => strct (subst_mems mems)
end
with subst_mem (e : member) {struct e} : member :=
match e with
| membr T rhs => membr (subst_typ T) (subst_trm rhs)
end
with subst_mems (e : list member) {struct e} : list member :=
match e with
| nil => nil
| cons m ms => cons (subst_mem m) (subst_mems ms)
(* Error:
Recursive call to subst_mem has principal argument equal to
"m"
instead of ms
end.
This is not a Function limitation but a Fixpoint one.
Coq only allows the user to define a mutual recursive functions over
mutually recursively defined inductives. So that you can not defined
subst_mems in the same block as the three other functions.
In order not to inline the definition of lists, you can use a well- know trick constiting in inlining
the definition of subst_mems itself as follows:
Fixpoint subst_trm (e : trm) {struct e} : trm :=
match e with
end
match e with
| strct mems =>
let subst_mems :=
fix subst_mems (mems:list member) {struct mems} :=
match mems with
| nil => nil
end
in
end
match e with
end
But this time you will lose the possibility of using Function since this feature does not support (and will not support for probably a long time)
so called local recursive definition.
Best regards,
Julien Forest
- [Coq-Club] functional induction and nested list's, Adriaan Moors
- Re: [Coq-Club] functional induction and nested list's,
Julien Forest
- Re: [Coq-Club] functional induction and nested list's, Adriaan Moors
- Re: [Coq-Club] functional induction and nested list's, Julien Forest
Julien Forest
