- To: Adriaan Moors <adriaan.moors AT gmail.com>
- Cc: coq-club AT pauillac.inria.fr
- Subject: Re: [Coq-Club] functional induction and nested list's
- Date: Wed, 9 Apr 2008 19:08:23 +0200
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=date:from:to:cc:subject:message-id:in-reply-to:references:organization:x-mailer:mime-version:content-type:content-transfer-encoding:sender; b=DOazxQCvVlgS9Ib+DM62o3pf3Mb6EmhKMiDEt6pwGrC7kg4WUPV+n/ZlZXYhqhuDwlU4GzunzBi+QkvmhBJujkdWneMlNgon8DeRSdFOfsTL028Pwy48uK3IfFiTUszt0uqoQku8qK95y+YL1aqQYi1aNLNR+XqD/rcGSjDk56g=
- Organization: CNAM
Dear Adriaan,
On Wed, 9 Apr 2008 16:47:50 +0200
Adriaan Moors
wrote:
> Thank you for the hint about inlining subst_mems! Is it discussed in a
> FAQ that I should have read?
I'm not sure about that maybe someone else can give you a pointer.
> I implemented your suggestion, and now my fixpoint is accepted, but on
> using Functional Scheme, I get:
> "Anomaly: add_args : todo. Please report."
1- The error message is not the good one !
2- Yes. For now, and once again probably for a long time, such a body cannot
be accepted.
> Is this the restriction you mentioned? I guess the only way to use
> functional induction without defining the (huge) induction principles
> by hand (which I've already done for the normal induction principles)
> is to remove nested occurrences of list etc in my datatypes (as
> illustrated in my example below). That'd be quite unfortunate :-(
> cheers,
> adriaan
Cheers,
Julien.
ps: can you send me (by private mail we do not need to polute this list) the
version of coq you use so that I can correct the error message.
J.
- [Coq-Club] functional induction and nested list's, Adriaan Moors
- Re: [Coq-Club] functional induction and nested list's,
Julien Forest
Adriaan Moors
- Re: [Coq-Club] functional induction and nested list's, Julien Forest
Adriaan Moors
Julien Forest
