- From: Conor McBride <conor AT strictlypositive.org>
- To: Coq Club <coq-club AT pauillac.inria.fr>
- Subject: Re: [Coq-Club] Coinductive types and type preservation.
- Date: Fri, 6 Jun 2008 15:44:27 +0100
Hi folks
Nils Anders Danielsson just raised Nicolas's question
on the Agda list, so at risk of duplication, I'll
observe that...
On 6 Jun 2008, at 15:09, Nicolas Oury wrote:
Greetings,
I was playing with CoInductive types in Coq and found this problem:
(*if you define the type of streams of units:*)
CoInductive Stream : Set :=
| cons : Stream -> Stream.
CoFixpoint ones : Stream := cons ones.
(*and a function out such that out (cons xs) := cons xs *)
Definition out (xs : Stream) : Stream :=
match xs with
| cons ys => cons ys
end.
Require Import Logic.
(*Then you can prove: forall xs, xs = out xs *)
Lemma out_eq (xs : Stream) : xs = out xs .
intros xs.
case_eq xs.
intros s eq.
reflexivity.
...this should not work.
(out (cons xs)) should not compute to (cons xs)
except en passant, in an outer case analysis
demanding to strip the cons.
If you write
Definition bout (xs : Stream) : bool :=
match xs with
| cons ys => true
end.
then we should have
refl : bout (out (cons xs)) = bout (cons xs)
But without such a bout, not at all!
Defined.
(* This seems not to be a problem, but we can deduce *)
Definition p : ones = cons ones
Canonicity tells us that p's type should not
be inhabited.
Rather worryingly, this does suggest that
the contexts in which coinductive computation
should happen are perhaps rather more subtly
distinguished than we might have hoped. Perhaps
they may even be type-directed.
Well done, Nicolas, for spotting this problem!
All the best
Conor
- [Coq-Club] Coinductive types and type preservation., Nicolas Oury
- Re: [Coq-Club] Coinductive types and type preservation., Conor McBride
Arnaud Spiwack
- Re: [Coq-Club] Coinductive types and type preservation., Nicolas Oury
roconnor
Conor McBride
roconnor
roconnor
Bruno Barras
- Re: [Coq-Club] Coinductive types and type preservation., Thorsten Altenkirch
Bruno Barras
- Re: [Coq-Club] Coinductive types and type preservation., roconnor
roconnor
roconnor
Conor McBride
Arnaud Spiwack
