- From: Conor McBride <conor AT strictlypositive.org>
- To: Coq Club <coq-club AT pauillac.inria.fr>
- Subject: Re: [Coq-Club] Coinductive types and type preservation.
- Date: Sat, 7 Jun 2008 10:36:45 +0100
Hi Russell
On 7 Jun 2008, at 07:18,
roconnor AT theorem.ca
wrote:
On Fri, 6 Jun 2008, Conor McBride wrote:
Definition p : ones = cons ones
Canonicity tells us that p's type should not
be inhabited.
Why shouldn't ones and (cons ones) be convertable? Can't we just expand the cofixpoint of ones until the same number of constructors are exposed as is in (cons ones), and then compare the resulting terms?
You're right. Indeed, I've been known to suggest such
a thing. (Again, there's been some chat about it on
the Agda mailing list: coinduction has just arrived
in Agda and is getting some serious testing.) And..(*)
Nicolas's example highlights an imbalance between
match's enthusiasm for unfolding and conversion's
reluctance. It seems that one could restore this
balance in one of two ways: making match lazier,
or making conversion more enthusiastic.
I'm very much in favour of separating evaluation
from definitional equality (with the latter being
a type-indexed family of equivalences on values).
Definitional equality doesn't have to be some
(suitably optimized) alpha-equivalence of normal
forms arising from some SN and CR rewrite system.
If you want ones = cons ones, definitionally, you
clearly need to do more work in equality than you
do in evaluation.
I'm probably being naive here.
(*)..the jury's out. I wrote an email to the Agda
list yesterday which was really enthusiastic
about this at the start and then more troubled at
the end. It seems very sensitive to the setup.
Problem 1: races
If I define
oneones = cons (cons oneones)
should
oneones = cons oneones ?
It's clearly dangerous to play this game too
often, although we clearly need
ones = cons (cons ones)
Solution 1: no overtaking
We're not trying to find simulations here;
we're trying to get a more liberal intensional
match, so when we see x = cocon ..., we just
want to know if x can be unfolded to the
cocon... expression. If unfolding x jumps over
the rhs, then it's not the same mechanism at
work. cons oneones is out of phase with
oneones, so they shouldn't be equal.
Problem 2: transitivity
Define
fred = cons fred
jim = cons fred
Should fred = jim? Yes, if both defining
equations hold, but where's the provocation
to unfold? If you want this to work, you
need to ensure that fred can only be defined
lazily and that jim cannot be defined lazily,
or is otherwise seen to be unfoldable without
provocation.
Solution 2: ????????????
But I have an idea, based on taking the
one-step coalgebra as the primitive notion,
and coding more liberal notions of CoFix.
This (I hope) prevents definitions such as
jim being expressed as degenerate cofixpoints.
As the numbering scheme should suggest, there
may be other problems. The snakes are very
definitely alive, but I'm still optimistic
and on the case.
We live in interesting times.
All the best
Conor
- [Coq-Club] Coinductive types and type preservation., Nicolas Oury
- Re: [Coq-Club] Coinductive types and type preservation.,
Conor McBride
Arnaud Spiwack
- Re: [Coq-Club] Coinductive types and type preservation., Conor McBride
- Re: [Coq-Club] Coinductive types and type preservation., Nicolas Oury
roconnor
roconnor
roconnor
Bruno Barras
- Re: [Coq-Club] Coinductive types and type preservation., Thorsten Altenkirch
Bruno Barras
- Re: [Coq-Club] Coinductive types and type preservation., roconnor
roconnor
roconnor
Arnaud Spiwack
- Re: [Coq-Club] Coinductive types and type preservation., Adam Chlipala
- Re: [Coq-Club] Coinductive types and type preservation., Carlos . SIMPSON
Conor McBride
