- To: Nicolas Oury <npo AT Cs.Nott.AC.UK>
- Cc: coq-club AT pauillac.inria.fr
- Subject: Re: [Coq-Club] Coinductive types and type preservation.
- Date: Fri, 06 Jun 2008 10:47:56 -0400
The behavior isn't surprising to me given what I understand of the reduction rules for co-inductive types. [cofix]es are only expanded when they are [match]ed on. The definition of [p] includes [match]ing on the [cofix] from the definition of [ones], but that matching can be simplified to reflexivity, apparently after it plays a crucial role in getting [p] to type-check at the type you want. There's no matching anywhere in the definition of [p2], so the type checker can never "look inside" the definition of [ones] effectively.
While this makes sense working through the reduction rules mechanistically, it certainly is surprisingly that normalization can prevent a term from being assigned a type that it was assigned before. It doesn't look to me like the normal form is _ill-typed_, though, just that it can't be assigned the type that the original had. Maybe someone involved with the theory and implementation of co-inductive types can comment on the deeper consequences of this.
Nicolas Oury wrote:
(*if you define the type of streams of units:*)
CoInductive Stream : Set :=
| cons : Stream -> Stream.
CoFixpoint ones : Stream := cons ones.
(*and a function out such that out (cons xs) := cons xs *)
Definition out (xs : Stream) : Stream :=
match xs with
| cons ys => cons ys
end.
Require Import Logic.
(*Then you can prove: forall xs, xs = out xs *)
Lemma out_eq (xs : Stream) : xs = out xs .
intros xs.
case_eq xs.
intros s eq.
reflexivity.
Defined.
(* This seems not to be a problem, but we can deduce *)
Definition p : ones = cons ones := out_eq ones.
(* Now, if we want to see how this is proved: *)
Eval compute in p. (* returns refl_equal (cons (cofix ones : Stream := cons ones)) *)
(* but if we feed back the normal form *)
Definition p2 : ones = cons ones :=
refl_equal (cons (cofix ones : Stream := cons ones)).
(* the type checker yells that ones and cons ones are not convertible *)
It seems there is a well-typed term whose normal form is not well-typed.
That's probably not threatening for the safety of the system, because ones and cons ones are extensionaly equal.
But it's still a bit troubling that type preservation does not hold.
Am I missing something?
Is it a known problem with coinductive types?
- Re: [Coq-Club] Coinductive types and type preservation., (continued)
Arnaud Spiwack
- Re: [Coq-Club] Coinductive types and type preservation., Conor McBride
- Re: [Coq-Club] Coinductive types and type preservation., Nicolas Oury
roconnor
Conor McBride
roconnor
roconnor
Bruno Barras
- Re: [Coq-Club] Coinductive types and type preservation., Thorsten Altenkirch
Bruno Barras
- Re: [Coq-Club] Coinductive types and type preservation., roconnor
roconnor
roconnor
Conor McBride
- Re: [Coq-Club] Coinductive types and type preservation., Adam Chlipala
- Re: [Coq-Club] Coinductive types and type preservation., Carlos . SIMPSON
Arnaud Spiwack
