coq-club - Re: [Coq-Club] Coinductive types and type preservation.
chronological Thread
  • To: Conor McBride <conor AT strictlypositive.org>
  • Cc: Coq Club <coq-club AT pauillac.inria.fr>
  • Subject: Re: [Coq-Club] Coinductive types and type preservation.
  • Date: Sat, 7 Jun 2008 15:04:41 -0400 (EDT)
On Sat, 7 Jun 2008, Conor McBride wrote:
Problem 1: races
If I define
  oneones = cons (cons oneones)
should
  oneones = cons oneones ?
It's clearly dangerous to play this game too
often, although we clearly need
  ones = cons (cons ones)
Solution 1: no overtaking
We're not trying to find simulations here;
we're trying to get a more liberal intensional
match, so when we see x = cocon ..., we just
want to know if x can be unfolded to the
cocon... expression. If unfolding x jumps over
the rhs, then it's not the same mechanism at
work. cons oneones is out of phase with
oneones, so they shouldn't be equal.
Right. I thought about this an hour after I sent my email. The problem is that we really want the lemma forall x:Stream, x=cons x to hold because exactly the same proof holds for
Inductive Stream' : Type := cons' : Stream' -> Stream'.
I'd wager that (forall x:Stream, x=cons x) ought to hold for any fixed point of Identity, whether it is greatest, least, or otherwise.
Perhaps if we treat oneones as shorthand for two mutually recursive cofixpoints (each cofixpoint exposing exactly one constructor), we can mangage to pull only one constructor at a time. Then (because of the symmetry existing between the form of the mutually recursive cofixpoints) we will see that (cons oneones) is convertable to oneones.
But I worry that there are (as you say) more snakes. CoInductive types are very strange. They are the only objects where computation "simplfies" the introduction rule (cofix) rather than simplifying the elimination rule.
Problem 2: transitivity
Define
  fred = cons fred
  jim = cons fred
Should fred = jim? Yes, if both defining
equations hold, but where's the provocation
to unfold? If you want this to work, you
need to ensure that fred can only be defined
lazily and that jim cannot be defined lazily,
or is otherwise seen to be unfoldable without
provocation.
Solution 2: ????????????
But I have an idea, based on taking the
one-step coalgebra as the primitive notion,
and coding more liberal notions of CoFix.
This (I hope) prevents definitions such as
jim being expressed as degenerate cofixpoints.
Ah, one-step coalgebra sounds like what I said above.
As the numbering scheme should suggest, there
may be other problems. The snakes are very
definitely alive, but I'm still optimistic
and on the case.
We live in interesting times.
It seems that without European TYPES funding, the theory of types is starting to fall apart. Who knew it was the money that was holding it together. ;)
Russell O'Connor                                      <http://r6.ca/>
``All talk about `theft,''' the general counsel of the American Graphophone
Company wrote, ``is the merest claptrap, for there exists no property in
ideas musical, literary or artistic, except as defined by statute.''
