- From: Matthew Brecknell <coq-club AT brecknell.org>
- To: coq-club AT pauillac.inria.fr
- Subject: Re: [Coq-Club] Simple Transformation
- Date: Sun, 22 Feb 2009 17:16:55 +1000
Jeff Terrell wrote:
> So, at the risk of making myself unpopular, how would you prove the theorem
> using tactics like intro, exists, elim, split and so on. I think if I can
> see
> how to solve this simple problem by these means, it will help me to solve
> the
> more complex problem.
Since you insist, here is a monolithic proof of your conjecture using
low-level tactics. :-)
Theorem foo:
forall l : list Process, exists m : list Package,
forall p : Process, In p l -> exists a : Package,
In a m /\ PID p = AID a.
Proof.
induction l.
exists nil. unfold In. intros. elim H.
destruct IHl. exists (Build_Package (PID a) :: x). simpl. intros.
destruct H0.
exists (Build_Package (PID a)). split.
left. reflexivity.
rewrite H0. reflexivity.
destruct (H p H0). destruct H1. exists x0. split.
right. assumption.
assumption.
Qed.
The above is likely to be quite fragile, so you'll probably want to
replay it in the same version I used to check it: version 8.2-1,
released a few days ago.
Now contrast that with the following approach, which makes use of
auxiliary definitions and lemmas provided in the List library:
Definition p2p p := Build_Package (PID p).
Theorem bar:
Proof.
Hint Resolve in_map.
intro l; exists (map p2p l); intro p; exists (p2p p); auto.
Qed.
You can look up the definitions of "map" and "in_map" in the library
sources to decide which approach results in a more robust and
understandable proof script. :-)
Regards,
Matthew
- [Coq-Club] Simple Transformation, Jeff Terrell
- Re: [Coq-Club] Simple Transformation,
Matthew Brecknell
Jeff Terrell
- Re: [Coq-Club] Simple Transformation, Luke Palmer
- Re: [Coq-Club] Simple Transformation, Matthew Brecknell
Jeff Terrell
- Re: [Coq-Club] Simple Transformation, Adam Chlipala
- [Coq-Club] Partial Witness,
Jeff Terrell
- Re: [Coq-Club] Partial Witness,
Adam Chlipala
Jeff Terrell
- Re: [Coq-Club] Partial Witness, Adam Chlipala
- Re: [Coq-Club] Partial Witness, Jeff Terrell
Jeff Terrell
Adam Chlipala
- Re: [Coq-Club] Partial Witness, Pierre Castéran
Jeff Terrell
Jeff Terrell
Matthew Brecknell
