coq-club - Re: [Coq-Club] Simple Transformation
chronological Thread
  • To: Jeff Terrell <jeff AT kc.com>
  • Cc: coq-club AT pauillac.inria.fr
  • Subject: Re: [Coq-Club] Simple Transformation
  • Date: Sun, 22 Feb 2009 09:06:21 -0500
Jeff Terrell wrote:
Is it possible to specify the name 'a' above (which appears to have come from the induction step at the beginning of the proof) and the name 'x' below (which is a witness of the existential quantification above)?
Read about elimination patterns in the manual. (You'll probably see them mentioned in the entries for [induction] and [destruct].)
Could you explain the difference between simpl and (a possible alternative) unfold In in this context. Both appear to do a similar sort of thing (although one is more concise than the other), and both work.
Have you read the manual entries on those tactics?
