- To: Jeff Terrell <jeff AT kc.com>
- Cc: coq-club AT pauillac.inria.fr
- Subject: Re: [Coq-Club] Partial Witness
- Date: Sat, 28 Feb 2009 08:59:54 -0500
Jeff Terrell wrote:
Adam Chlipala wrote:
Jeff Terrell wrote:
1 subgoal
p' : Process
l : list Process
mw : list Package
H : forall p : Process,
In p l ->
exists a : Package,
In a mw /\
PID p = AID a /\ (forall n : nat, In n (X p) -> n > 0 -> In n (Y a))
exists m : list Package,
forall p : Process,
In p (p' :: l) ->
exists a : Package,
In a m /\
T < exists (Build_Package (PID p') ??????? :: mw).
Don't you just want to put [(X p')] in the blank? I can't spot anything tricky going on here.
Unless the specification is wrong, the intention was for Y to contain a subset of the numbers in X, so that (X p') *wouldn't* be a valid witness for Y. What am I missing?
It's more than your specification being wrong: your understanding of what a specification is is wrong. ;-) (But, putting that aside, you "specification" is "wrong" relative to your stated intentions, in the sense that the inner existential witness need not include any filtering and may even add new list elements, as long as every old element is kept.)
You are proving a theorem whose type belongs to [Prop]. That means the proof really is a proof, and every proof is equivalent computationally. There is never any reason to prefer any proof to another, putting aside issues of how difficult different proof strategies are to code.
You are probably operating under the misconception that Coq is commonly used to "extract programs from proofs." Hardly anyone does this, in Coq or any other system. Rather, Coq is more like a rich programming environment with a compilation toolchain by way of extraction to OCaml.
You could restate your problem with product types in place of conjunction and sigma types in place of [exists], and then it would be possible to use tactical proof search to build a real _program_, rather than a purely mathematical _proof_, as you are doing now.
I'm sure I've used many terms and concepts in this message that you aren't familiar with. Thus, my meta-message is that you should read a book on Coq, rather than jumping right into an implementation, where you assume you already have the right intuitions to make do with the manual alone.
- Re: [Coq-Club] Simple Transformation, (continued)
Matthew Brecknell
Jeff Terrell
- Re: [Coq-Club] Simple Transformation, Luke Palmer
Matthew Brecknell
Jeff Terrell
- Re: [Coq-Club] Simple Transformation, Adam Chlipala
- Re: [Coq-Club] Simple Transformation, Matthew Brecknell
- [Coq-Club] Partial Witness,
Jeff Terrell
- Re: [Coq-Club] Partial Witness,
Adam Chlipala
Jeff Terrell
- Re: [Coq-Club] Partial Witness, Adam Chlipala
- Re: [Coq-Club] Partial Witness, Jeff Terrell
Jeff Terrell
Adam Chlipala
- Re: [Coq-Club] Partial Witness, Pierre Castéran
Jeff Terrell
Jeff Terrell
Matthew Brecknell
