- To: jeff AT kc.com
- Cc: coq-club AT pauillac.inria.fr
- Subject: Re: [Coq-Club] Simple Transformation
- Date: Sun, 22 Feb 2009 16:31:03 +0200
Hi Jeff.
If you are not afraid of the lowest level, here is the proof using only
lambda terms:
Goal forall l : list Process,
exists m : list Package,
forall p : Process,
In p l -> exists a : Package,
In a m /\
PID p = AID a.
Proof.
refine (fix rec (l:list Process) := _).
refine (match l as l return exists m, forall p, In p l -> (_:Prop)
with nil => _ | p0 :: l0 => _ end).
refine (ex_intro _ nil _).
refine (fun _ f => match f with end).
simpl.
refine (let rec0 := rec l0 in _).
refine (match rec0 with ex_intro m0 rec1 => _ end).
clear rec0.
refine (ex_intro _ (Build_Package (PID p0) :: m0) _).
simpl.
refine (fun p or0 => _).
refine (match or0 with or_introl eq0 => _
| or_intror in0 => _ end).
refine (ex_intro _ (Build_Package (PID p0)) _).
refine (conj (or_introl _ (refl_equal _)) _).
simpl.
refine (f_equal _ (sym_eq eq0)).
refine (match rec1 p in0 with ex_intro a1 and1 => _ end).
refine (ex_intro _ a1 (conj
(or_intror _ (proj1 and1)) (proj2 and1))).
Save.
Date: Sat, 21 Feb 2009 15:46:52 +0000--
<jeff AT kc.com>
...how would you prove the theorem using tactics like intro, exists, elim, split and so on.
Best regards,
Roman Beslik.
- Re: [Coq-Club] Simple Transformation, (continued)
Jeff Terrell
- Re: [Coq-Club] Simple Transformation, Adam Chlipala
- Re: [Coq-Club] Simple Transformation, Matthew Brecknell
- [Coq-Club] Partial Witness,
Jeff Terrell
- Re: [Coq-Club] Partial Witness,
Adam Chlipala
Jeff Terrell
- Re: [Coq-Club] Partial Witness, Adam Chlipala
- Re: [Coq-Club] Partial Witness, Jeff Terrell
Jeff Terrell
Adam Chlipala
- Re: [Coq-Club] Partial Witness, Pierre Castéran
Jeff Terrell
