coq-club - Re: [Coq-Club] Partial Witness
chronological Thread
  • To: Matthew Brecknell <coq-club AT brecknell.org>
  • Cc: coq-club AT pauillac.inria.fr
  • Subject: Re: [Coq-Club] Partial Witness
  • Date: Tue, 03 Mar 2009 13:59:41 +0000
Dear Matthew,
Matthew Brecknell wrote:
Jeff Terrell wrote:
Unless the specification is wrong, the intention was for Y to contain a subset of the numbers in X, so that (X p') *wouldn't* be a valid witness for Y. What am I missing?
Reading between the lines, I'm wondering if you might actually have
meant to write this:
Theorem T :
forall l : list Process, exists m : list Package,
  forall p : Process, In p l -> exists a : Package,
    In a m /\
    PID p = AID a /\
    forall n : nat,
      In n (X p) /\ n > 0 <-> In n (Y a).
That is, a number is in Y if *and only if* it is in the corresponding X
and it is greater than 0. Note the double-headed arrow.
What I was trying to do was to come up with an example in which a witness *couldn't* be constructed from constraints in the current goal, because I was keen to understand how to deal with such a situation. Unfortunately, I messed up the theorem and that led to some confusion; I'm sorry to everyone for that.
I'm grateful to Adam for pointing out something that just didn't occur to me, and that is that as *I'd* defined the theorem, any list of numbers could serve as a witness for Y, provided that it included the positive numbers in X. And one such witness, of course, is (X p').
Your theorem above tie things down quite nicely - many thanks for that. But I was also wondering (for curiosity sake more than anything else) whether <-> could be replaced by ->, if the implicand constrained Y to be the smallest possible list. If that were possible, (X p') wouldn't then be a witness.
With regard to your original question about "partial witnesses": since
you're providing the proof, you must know what constraints the witness
will ultimately need to satisfy, so just construct and provide an
appropriate witness. You don't need to wait until the constraints come
to the front of the goal. However, assuming you have provided an
appropriate witness, then when those constraints do come to the front of
the goal, they should be easy to satisfy.
This is exactly the sort of example that I was looking for. The problem it solves is the one that prompted me to ask about partial witnesses in the first place. Many thanks for your help.
Regards,
Jeff.
Here's the proof:
Require Import List Compare_dec Omega.
Record Process : Set := {PID : nat; X : list nat}.
Record Package : Set := {AID : nat; Y : list nat}.
Fixpoint gt0_filter (ns: list nat) : list nat :=
  match ns with
    | n :: r => if zerop n then gt0_filter r else n :: gt0_filter r
    | nil => nil
  end.
Definition p2p proc := Build_Package (PID proc) (gt0_filter (X proc)).
Lemma gt0_filter_In_fwd:
  forall (ns: list nat) (n: nat),
  In n ns /\ n > 0 -> In n (gt0_filter ns).
Proof.
  induction ns; simpl; intuition;
  match goal with
    | [ |- context [ if zerop ?X then ?Y else ?Z ] ]
      => destruct (zerop X)
  end;
  try (apply False_ind; omega);
  try (apply IHns);
  simpl; auto.
Qed.
Lemma gt0_filter_In_rev:
  In n (gt0_filter ns) -> In n ns /\ n > 0.
Proof.
  match goal with
    | [ H: context [ if zerop ?X then ?Y else ?Z ] |- _ ]
  end; simpl in *; intuition;
  match goal with
    | [ H: In ?N (gt0_filter ?NS) |- _ ]
      => generalize (IHns N H); intuition
  end.
Qed.
Theorem T :
      In a m /\
      PID p = AID a /\
      forall n : nat,
Proof.
  Hint Resolve gt0_filter_In_fwd gt0_filter_In_rev in_map.
  intro l; exists (map p2p l); intro p; exists (p2p p);
  repeat (split; simpl; auto).
Qed.
Bug reports: http://logical.saclay.inria.fr/coq-bugs
Archives: http://pauillac.inria.fr/pipermail/coq-club
          http://pauillac.inria.fr/bin/wilma/coq-club
Info: http://pauillac.inria.fr/mailman/listinfo/coq-club
