- To: Jeff Terrell <jeff AT kc.com>
- Cc: coq-club AT pauillac.inria.fr
- Subject: Re: [Coq-Club] Partial Witness
- Date: Tue, 03 Mar 2009 09:33:23 -0500
Jeff Terrell wrote:
Dear Adam,
Adam Chlipala wrote:
Your theorem above tie things down quite nicely - many thanks for that. But I was also wondering (for curiosity sake more than anything else) whether <-> could be replaced by ->, if the implicand constrained Y to be the smallest possible list. If that were possible, (X p') wouldn't then be a witness.
Do you have some convention in mind for doing such constraining with an implication? I've never seen such a feature in logic or math, on paper or on a computer. You could certainly do it with an extra conjunction and universally-quantified fact, though.
I hope I've used the right terminology. I suggested constraining the implicand, not the implication. As far as I'm aware, the implicand is the conclusion of the implication.
Right, I understood that. The problem is that you are trying to make a "non-local statement" about the range of a quantifier that occurs outside the implicand, where you are only allowed to mention one value of the quantified variable "at a time." I don't know how to do that without using computational effects in the fairly exotic way that linguists use them to model some features of natural language.
- Re: [Coq-Club] Partial Witness, Roman Beslik
- <Possible follow-ups>
- Re: [Coq-Club] Partial Witness, Matthew Brecknell
Matthew Brecknell
Jeff Terrell
Adam Chlipala
Jeff Terrell
- Re: [Coq-Club] Partial Witness, Adam Chlipala
Jeff Terrell
Adam Chlipala
Jeff Terrell
Hugo Herbelin
Adam Chlipala
- Re: [Coq-Club] Partial Witness, Hugo Herbelin
Adam Chlipala
