- From: Matthew Brecknell <coq-club AT brecknell.org>
- To: coq-club AT pauillac.inria.fr
- Subject: Re: [Coq-Club] Partial Witness
- Date: Wed, 04 Mar 2009 10:07:44 +1000
Jeff Terrell wrote:
> What I was trying to do was to come up with an example in which a witness
> *couldn't* be constructed from constraints in the current goal, because I
> was
> keen to understand how to deal with such a situation. Unfortunately, I
> messed up
> the theorem and that led to some confusion; I'm sorry to everyone for that.
There's no substitute for understanding the thing you are attempting to
formalise. If you're unable to imagine what properties a witness must
satisfy, it's unlikely you'll be able to prove much of interest.
Having said that, some tactics do generate existential meta-variables to
be determined in a later proof step. (In particular, various tactics
beginning with 'e', for example eauto). I don't know whether you might
be able to use meta-variables in your proof. Perhaps someone else can
comment?
> Your theorem above tie things down quite nicely - many thanks for that. But
> I
> was also wondering (for curiosity sake more than anything else) whether <->
> could be replaced by ->, if the implicand constrained Y to be the smallest
> possible list. If that were possible, (X p') wouldn't then be a witness.
You could write something like this (which is really just factoring out
the extra conjunction and quantification which Adam described):
Inductive shortest (A: Type) (P: list A -> Prop) : list A -> Prop :=
| is_shortest: forall x, P x
-> (forall y, P y -> length x <= length y)
-> shortest A P x.
Implicit Arguments shortest [A].
Theorem T :
forall l : list Process, exists m : list Package,
forall p : Process, In p l -> exists a : Package,
In a m /\
PID p = AID a /\
shortest
(fun y => forall n, In n (X p) -> n > 0 -> In n y)
(Y a).
I think this is actually stronger than the previous formulation, since
it also disallows duplicates. I've not attempted a proof, though I
imagine you would want to start with some lemmas relating shortest and
In.
Regards,
Matthew
PS - I apologise for my previous double-post. I initially sent it by
accident from a non-subscribed address, and falsely presumed it had been
dropped when it hadn't come through for a while. I realise now that it
was probably sitting in a queue for moderation.
- Re: [Coq-Club] Partial Witness, Roman Beslik
- <Possible follow-ups>
- Re: [Coq-Club] Partial Witness, Matthew Brecknell
Matthew Brecknell
Jeff Terrell
Adam Chlipala
Jeff Terrell
- Re: [Coq-Club] Partial Witness, Adam Chlipala
Jeff Terrell
Adam Chlipala
Jeff Terrell
Hugo Herbelin
Adam Chlipala
- Re: [Coq-Club] Partial Witness, Hugo Herbelin
Adam Chlipala
