- To: Taral <taralx AT gmail.com>
- Cc: coq-club AT pauillac.inria.fr
- Subject: Re: [Coq-Club] C-zar proof help
- Date: Wed, 4 Mar 2009 16:38:30 +0000
Hi Taral,
Thanks for taking a look at my problem!
On Tue, Mar 03, 2009 at 02:53:18PM -0800, Taral wrote:
> On Tue, Mar 3, 2009 at 2:43 PM, Taral
> wrote:
> > You need to expose (commute (up, uq)) before taking cases on it. Also,
> > you cannot extract the hypothesis if you are going to case on a
> > subexpression.
You mean I can't do the
be such that (namedCommute (p, q) = Some (q', p')).
step, right? It's not obvious to me why that shouldn't also work.
> Does anyone know why "per cases on A. suppose it is B." doesn't just
> introduce "A = B" as a hypothesis?
If I understand you correctly, this is one of the things that confuses
me too. e.g. in the following lemma, the last line goes orange, whereas
I would expect it to be green:
Lemma Foo : forall (x : bool), ((x = true) \/ (x = false)).
proof.
let x : bool.
per cases on x.
suppose it is true.
then (x = true).
Thanks
Ian
- [Coq-Club] C-zar proof help, Ian Lynagh
- Re: [Coq-Club] C-zar proof help,
Adam Chlipala
Ian Lynagh
Adam Chlipala
- Re: [Coq-Club] C-zar proof help, Ian Lynagh
Adam Chlipala
Ian Lynagh
- Re: [Coq-Club] C-zar proof help, Pierre Corbineau
- Re: [Coq-Club] C-zar proof help, Taral
Taral
Taral
Taral
Ian Lynagh
Taral
- Re: [Coq-Club] C-zar proof help, Hugo Herbelin
- Re: [Coq-Club] C-zar proof help, Sean Wilson
Taral
Ian Lynagh
Taral
Taral
Adam Chlipala
