- To: Julien Forest <forest AT ensiie.fr>
- Cc: coq-club AT pauillac.inria.fr
- Subject: Re: [Coq-Club] families of sets extension
- Date: Mon, 30 Mar 2009 14:17:35 +0200
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:in-reply-to:references:date:message-id:subject:from:to :cc:content-type; b=MYCLjTjFfQ181nOevIA1HnQadqeQpaiTGtu/I2NE6uB8haOg8RI/Sd5tilJTEbnbmL 3GdsN/FUjql3XTS1mhzQw2G6LrRHEjXi/4+wzHqKy1/p2RPbqE6pFJtrYMulMkqWMzH/ Z0gWq5rEg1P1bcrtK3pZFHYBcm5AYHQqUDhvc=
Thanks a lot, Julien.
Cesar
2009/3/30 Julien Forest <forest AT ensiie.fr>
On Mon, 30 Mar 2009 13:26:51 +0200
anabelcesar <anabelcesar AT gmail.com> wrote:
> Dear Coq users,
> I am working with families of sets F:nat -> Set and I need to
> extend them using a particular set as the first set of the family.
> In the example below, I use "unit".
> Then, If we iterate the construction n times, the n first sets should be
> unit
> (and in particular the set n in the family). But I do not know how to prove
> this
> (probably easy) Lemma.
> Any help is appreciated.
> Cesar
> Section Function_extension.
> Variable F:nat-> Set.
> Definition unit_ext: nat -> Set:=
> fun n : nat => match n with
> | 0 => unit
> | S n0 => F n0
> end.
> End Function_extension.
> Fixpoint iterated_unit_ext ( F:nat-> Set)(n:nat){struct n}:=
> match n with
> | 0 => unit_ext F
> | S n => iterated_unit_ext (unit_ext F) n
> end.
> Lemma aa:forall (n:nat) (F:nat -> Set), iterated_unit_ext F n n = unit.
> Proof.
Hi,
the trick is to prove first that:
Lemma lem1 : forall n m F, iterated_unit_ext F (S n) m = unit_ext (iterated_unit_ext F n) m.
| 0 => unit
| S n0 => F n0
end.
match n with
| 0 => unit_ext F
end.
(iterated_unit_ext F n) m. Proof.
induction n as [|n].
simpl;reflexivity.
simpl.
intros.
rewrite <- IHn. simpl;reflexivity.
Qed.
Proof.
simpl. reflexivity.
intros.
rewrite lem2.
simpl.
auto.
Qed.
- [Coq-Club] families of sets extension, anabelcesar
- Re: [Coq-Club] families of sets extension,
Julien Forest
- Re: [Coq-Club] families of sets extension, anabelcesar
Stéphane Lescuyer
Edsko de Vries
Stéphane Lescuyer
James McKinna
- Re: [Coq-Club] families of sets extension, Sean Wilson
James McKinna
Stéphane Lescuyer
Edsko de Vries
- <Possible follow-ups>
Julien Forest
