coq-club - Re: [Coq-Club] families of sets extension
chronological Thread
  • To: St�phane Lescuyer <lescuyer AT lri.fr>, Edsko de Vries <devriese AT cs.tcd.ie>
  • Cc: Julien Forest <forest AT ensiie.fr>, anabelcesar <anabelcesar AT gmail.com>, coq-club AT pauillac.inria.fr, Andrew Ireland <a.ireland AT hw.ac.uk>
  • Subject: Re: [Coq-Club] families of sets extension
  • Date: Mon, 30 Mar 2009 16:45:38 +0200
  • Organization: Radboud Universiteit Nijmegen
Dear Edsko, and others,
a simpler example might be to try to show, for example, commutativity of addition on natural numbers defined tail-recursively as
plus 0 n = n
plus (S m) n = plus m (S n)
We discussed this problem (and automatic techniques for solving it, due to Andrew Ireland and Alan Bundy in particular) at the Dagstuhl 9350 meeting in 1995...
   http://www.dagstuhl.de/en/program/calendar/semhp/?semnr=9530
But I can't find Andrew's paper on it out there in TV-land ("Rippling to meet the challenge", I think it was called, given during the last session on challenge problems). You might check with him directly...
best wishes,
James McKinna
Stéphane Lescuyer wrote:
Well, arguably, the most "canonical" example is just fold_left vs.
fold_right on lists. If you need to prove a property on (fold_left f l
i) by induction on the list l, you can use fold_left_rev_right (in the
standard library) to change the fold_left in a fold_right on (rev l),
and then use rev_induction (induction on the reverse of a list).
The advantage of fold_right is that the recursive call has the same
arguments than the current call, so you can use your IH directly
without stating particular invariants on the accumulator.
Incidentally, that's the way the induction principle for finite sets
in FSetProperties was proved (and the reason why it was proved as well
:-) because I was quickly fed up of doing all this manually).
Stéphane L.
2009/3/30 Edsko de Vries
<devriese AT cs.tcd.ie>:
Hi,
On 30 Mar 2009, at 13:21, Stéphane Lescuyer wrote:
To rebound on Julien's reply, just a more general remark : it is
almost always harder to reason about tail-recursive functions because
you need to manually introduce the adequate invariant on the
accumulator  (in that case, the function F) in your induction
principles.
For instance, to prove your lemma, you could have proven the following
(more general) result by induction on n, by adding a property on F :
Lemma for_aa : forall (n nf : nat) (F : nat -> Set),
 (forall m, m < nf -> F m = unit) ->
 forall m, m <= n+nf -> iterated_unit_ext F n m = unit.
A good way to proceed is Julien's : start by writing a lemma showing
that your function is equal to the non tail-recursive version you
could have written. Then use this lemma to rewrite instead of using
conversion.
I just wanted to emphasize that you can use Julien's solution in many
cases since it is more general that it may look.
That is very interesting, thanks for that remark. Are you aware of other
examples of this that I could look up?
Edsko
Bug reports: http://logical.saclay.inria.fr/coq-bugs
Archives: http://pauillac.inria.fr/pipermail/coq-club
        http://pauillac.inria.fr/bin/wilma/coq-club
Info: http://pauillac.inria.fr/mailman/listinfo/coq-club
