coq-club - [Coq-Club] Getting Program's postcondition with a two-level dependent pattern matching?
chronological Thread
  • To: coq-club <coq-club AT pauillac.inria.fr>
  • Subject: [Coq-Club] Getting Program's postcondition with a two-level dependent pattern matching?
  • Date: Sat, 27 Jun 2009 21:54:56 +0200
  • Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:from:date:message-id:subject:to:content-type; b=rG3mNAU3n8IlYleCYaearG5uAIrjlpZ2oXf0EkafUXQ7f5Dc4j1ZfShgukYSSdH+3U vsCTfjfnrhxSRlii0x+TUbwdYGKJDhhbpOBJ+dgfji/KiEWbuA0U3j60K0xtIfIuZuPG Wk9Jm7wTagFzrJQsIIBZP83U/ocjfXDJDVY2g=
   Dear all, (or should I say: Dear Matthieu? ;)
  This is a follow-up question to what I wrote few days ago (http://logical.saclay.inria.fr/coq-puma/messages/4810f6a2bb3fff04). Then I was having problems with reducibility of a Program-defined function, which I needed to prove an accompanying lemma about this function. As a matter of fact, I'd rather make this lemma a part of the specification of this function. However I have a dependently typed pattern matching with two nested recursive calls in one of the branches and I'm lost as to how to obtain post-conditions for those recursive calls. Please see the attached code (btw. is there a better way to get equalities for the dependent pattern matching?). All help greatly appreciated.
   Cheers,
   Adam
Require Import Relations Program Wf.
Set Implicit Arguments.
Inductive X : Type -> Type :=
| Nil : X True
| Seq : forall A B, X A -> X B -> X (A * B).
Definition Xtype T (x : X T) := T.
Inductive Res (T : Type) : Type :=
| Ok (n : nat) (res : T)
| Fail.
Implicit Arguments Fail [T].
Definition ctx := { T : Type & (X T * nat)%type }.
Definition build_ctx (T : Type) (x : X T) (n : nat) : ctx := existT _ T (x, n).
Axiom x_measure : relation ctx.
Axiom x_measure_wf : well_founded x_measure.
Axiom correct : forall T, X T -> nat -> Res T -> Prop.
Axiom correct_Nil : forall n, correct Nil n Fail.
Axiom correct_Seq_fail_l : forall A B n n' (el : X A) (er : X B),
  correct el n Fail -> correct (Seq el er) n' Fail.
Axiom correct_Seq_fail_r : forall A B n n' r (el : X A) (er : X B),
  correct el n (Ok n' r) -> correct er n' Fail -> correct (Seq el er) n' Fail.
Axiom correct_Seq_ok : forall A B n n' n'' r r' (el : X A) (er : X B),
  correct el n (Ok n' r) -> correct er n' (Ok n'' r') -> correct (Seq el er) n'' (Ok n'' (r, r')).
Program Fixpoint eval (T : Type) (x : X T) (n : nat)
  {measure (build_ctx x n) (x_measure)} :
  { r : Res T | correct x n r } :=
  match x as x' return JMeq x x' -> Res (Xtype x') with
  | Nil => fun H => Fail
  | Seq _ _ e1 e2 => fun H =>
      match eval e1 n with
      | Fail => Fail
      | Ok n' r =>
          match eval e2 n' with
          | Fail => Fail
          | Ok n'' r' =>
              Ok n'' (r, r')
          end
      end
  end _.
Next Obligation. Proof. Admitted.
Next Obligation.
Proof.
  destruct x; simpl.
  apply correct_Nil.
  (* [destruct_call eval] fails, because:
     [destruct (eval A x1 n (eval_obligation_1 eval (eval_obligation_3 eval)))]
    gives error:
     [Abstracting over the term "..." leads to a term "..." which is ill-typed]
Admitted.
Next Obligation.
Proof with auto.
  apply measure_wf. apply x_measure_wf.
Defined.
Adam.Koprowski AT gmail.com, http://www.cs.ru.nl/~Adam.Koprowski
The difference between impossible and possible
lies in determination (Tommy Lasorda)
