Re: [Coq-Club] Getting Program's postcondition with a two-level dependent pattern matching?
chronological Thread
- To: Adam Koprowski <adam.koprowski AT gmail.com>
- Cc: Coq Club <coq-club AT pauillac.inria.fr>
- Subject: Re: [Coq-Club] Getting Program's postcondition with a two-level dependent pattern matching?
- Date: Sun, 28 Jun 2009 08:19:12 -0400
Le 27 juin 09 à 19:53, Adam Koprowski a écrit :
In short, this works: [...]
Thanks! I'll try to see whether I can make it work on my real problem...
For the generation of equalities for the toplevel dependent pattern- matching,
you should get them for free! The automatic inference of the return predicate
was not getting the dependency of the return type in [x], but this can be fixed.
As a result, you get to prove the [correct] tcc in each branch instead of having
to destruct the whole term again and get into these dependency problems.
Indeed in my previous (simpler) version of this function, when [x] was not dependently typed, that was the case: I got one tcc per branch, with equality constraints and everything worked beautifully.
By 'this can be fixed' you mean the treatment of such cases by Program? Or is there anything I can do to avoid providing the return clause and benefiting from the Program's extra treatment of pattern matching?
It is fixed in the trunk now, enjoy !
-- Matthieu
- [Coq-Club] Getting Program's postcondition with a two-level dependent pattern matching?, Adam Koprowski
- Re: [Coq-Club] Getting Program's postcondition with a two-level dependent pattern matching?,
Matthieu Sozeau
Adam Koprowski
- Re: [Coq-Club] Getting Program's postcondition with a two-level dependent pattern matching?, Matthieu Sozeau
Adam Koprowski
Matthieu Sozeau
