Re: [Coq-Club] Getting Program's postcondition with a two-level dependent pattern matching?
chronological Thread
- To: Adam Koprowski <adam.koprowski AT gmail.com>
- Cc: Coq Club <coq-club AT pauillac.inria.fr>
- Subject: Re: [Coq-Club] Getting Program's postcondition with a two-level dependent pattern matching?
- Date: Sat, 27 Jun 2009 17:34:17 -0400
Le 27 juin 09 à 15:54, Adam Koprowski a écrit :
Dear all, (or should I say: Dear Matthieu? ;)
Hi Adam,
This is a follow-up question to what I wrote few days ago (http://logical.saclay.inria.fr/coq-puma/messages/4810f6a2bb3fff04 ). Then I was having problems with reducibility of a Program-defined function, which I needed to prove an accompanying lemma about this function. As a matter of fact, I'd rather make this lemma a part of the specification of this function. However I have a dependently typed pattern matching with two nested recursive calls in one of the branches and I'm lost as to how to obtain post-conditions for those recursive calls. Please see the attached code (btw. is there a better way to get equalities for the dependent pattern matching?). All help greatly appreciated.
The problem comes from the fact that [eval_obligation_2] has type:
forall (T : Type) (x : X T) (n : nat)
(eval : forall (T0 : Type) (x0 : X T0) (n0 : nat),
x_measure (build_ctx x0 n0) (build_ctx x n) ->
{r : Res T0 | correct x0 n0 r}) (Anonymous Anonymous0 : Type)
(e1 : X Anonymous) (e2 : X Anonymous0)
(H : [x : (X T)]= [Seq e1 e2 : (X (Anonymous * Anonymous0))])
(n' : nat) (r : Anonymous),
Ok n' r = `(eval Anonymous e1 n (eval_obligation_1 eval H)) ->
x_measure (build_ctx e2 n') (build_ctx x n)
The important part here being the [Ok n' r = `(eval ...)] assumption.
In the term, this obligation is applied to [Heq_anonymous], whose type would
gets abstracted if we abstract [eval A x1 n (eval_obligation_1 eval (eval_obligation_3 eval)],
to become [Ok n' r = s], making the new term ill-typed.
Under this circumstance, the only solution I know is to unfold the obligation
so that the abstraction works: the only way you can use this hypothesis in the
definition of the obligation is by destructing the [eval] anyway, making the
obligation abstract with respect to the result as well. You really need to
look at the term to see how it goes.
In short, this works:
Next Obligation. Proof. Admitted.
destruct_call eval.
(* You have to destruct it here so that you don't get another
rigid constant with an [Ok n' r = `(eval ...)] argument. *)
admit. Defined.
destruct x; simpl.
apply correct_Nil.
unfold eval_obligation_2. destruct_call eval. simpl. destruct x ; simpl.
destruct_call eval ; simpl. destruct x ; simpl. admit. admit. admit.
Qed.
Next Obligation.
Proof with auto.
apply measure_wf. apply x_measure_wf.
Defined.
For the generation of equalities for the toplevel dependent pattern- matching,
you should get them for free ! The automatic inference of the return predicate
was not getting the dependency of the return type in [x], but this can be fixed.
As a result, you get to prove the [correct] tcc in each branch instead of having
to destruct the whole term again and get into these dependency problems.
-- Matthieu
- [Coq-Club] Getting Program's postcondition with a two-level dependent pattern matching?, Adam Koprowski
- Re: [Coq-Club] Getting Program's postcondition with a two-level dependent pattern matching?, Matthieu Sozeau
