coq-club - Re: [Coq-Club] Getting Program's postcondition with a two-level dependent pattern matching?
chronological Thread
  • To: Matthieu Sozeau <mattam AT mattam.org>
  • Cc: Coq Club <coq-club AT pauillac.inria.fr>
  • Subject: Re: [Coq-Club] Getting Program's postcondition with a two-level dependent pattern matching?
  • Date: Sun, 28 Jun 2009 01:53:51 +0200
  • Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:in-reply-to:references:from:date:message-id:subject:to :cc:content-type; b=X9zPftoEXjiY8NGmxcgicMCggk6zy60RLcyJbGN2dErBFjP9O/YPP2ZUdowoJc43bg 061VIFC0wuk7clg9V+PiuUjdb2ID8KKG0UZAx/vfurRkay4P26UMj5G7rv/9on+LjPUM uMj1hLZdBNiGDulTMlm8cgwyUxm85CnaxXXmc=
In short, this works: [...]
  Thanks! I'll try to see whether I can make it work on my real problem...
For the generation of equalities for the toplevel dependent pattern-matching,
you should get them for free! The automatic inference of the return predicate
was not getting the dependency of the return type in [x], but this can be fixed.
As a result, you get to prove the [correct] tcc in each branch instead of having
to destruct the whole term again and get into these dependency problems.
  Indeed in my previous (simpler) version of this function, when [x] was not dependently typed, that was the case: I got one tcc per branch, with equality constraints and everything worked beautifully.
  By 'this can be fixed' you mean the treatment of such cases by Program? Or is there anything I can do to avoid providing the return clause and benefiting from the Program's extra treatment of pattern matching?
  Cheers,
   Adam
Adam.Koprowski AT gmail.com, http://www.cs.ru.nl/~Adam.Koprowski
The difference between impossible and possible
lies in determination (Tommy Lasorda)
