coq-club - [Coq-Club] case & inversion, Set & Prop
chronological Thread
  • To: coq-club AT pauillac.inria.fr
  • Subject: [Coq-Club] case & inversion, Set & Prop
  • Date: Thu, 06 Aug 2009 21:28:35 +0900 (JST)
Hello,
I have been confused by different behaviour of case and inversion tactics,
when I moved from Set to Prop.
Will someone please explain?
In the following code, the last "inversion h1" is not helpful at all.
Inductive list: Prop :=
| nil: nat -> list.
Inductive list_eq: list -> list -> Prop :=
| nil_eq: forall n, list_eq (nil n) (nil n).
Lemma inversion_list: forall l0 l1, list_eq l0 l1 -> list_eq l1 l0.
Proof.
intro l0. case l0. intro n0. intro l1.
case l1. intro n1. intro h1.
inversion h1. (* This changes nothing, so I've got stuck.)
The following two variations are fine:
1) Avoid the use of case:
| nil: nat -> list.
Proof.
intros l0 l1 h1. inversion h1. apply nil_eq.
Qed.
2) Change the kind of list from Prop to Set:
Inductive list: Set :=
| nil: nat -> list.
Proof.
intro l0. case l0. intro n0. intro l1. case l1. intro n1. intro h1. inversion
h1.
subst. apply nil_eq.
Qed.
Best,
Keiko
