- To: coq-club <coq-club AT pauillac.inria.fr>
- Subject: [Coq-Club] Need help with coinductive proof
- Date: Mon, 24 Aug 2009 16:28:38 +0100
Hi,
(I tried to keep this as short as I could, which means this cannot be copied&pasted into Coq as there are definitions missing; if anybody wants to experiment, the full file can be found at http://www.cs.tcd.ie/Edsko.de.Vries/conat.v)
I am stuck in a lemma, and would appreciate some suggestions. It is possible that the lemma is not true; if that is the case, I would like to know, too :) (I've tried hard to come up with a counter-example and failed, but that doesn't mean very much).
I have a definition of co-natural numbers, which include an 'add zero' constructor (as suggested by Adam a while back) and a sum constructor:
CoInductive conat : Set :=
| cozero : conat
| cosucc : conat -> conat
| coadd : conat -> conat -> conat
| coaddzero : conat -> conat.
I defined a function [flatten : conat -> conat] which removes [coadd]s (but not [coaddzero]s): basically, addition. We now define weak bisimularity (~) over conat's, so that 5 ~ 2 + 3 for instance and infinitely many [coaddzero (coaddzero (...))] ~ 0 but not to any number larger than 0. I define it in a process-calculus style, really just because I don't know how else; we set up an LTS, define the standard weak step (=>) relation, and set up the standard weak bisimilarity relation:
Inductive red_label := tau | succ.
Inductive red : red_label -> conat -> conat -> Prop :=
| red_cosucc : forall m,
red succ (cosucc m) m
| red_coadd : forall m n,
red tau (coadd m n) (flatten_conat (coadd m n))
| red_coaddzero : forall m,
red tau (coaddzero m) m.
Definition tau_steps := clos_refl_trans _ (red tau).
Inductive weak_hat : red_label -> conat -> conat -> Prop :=
| weak_hat_succ : forall m m' n' n,
tau_steps m m' ->
red succ m' n' ->
tau_steps n' n ->
weak_hat succ m n
| weak_hat_tau : forall m n,
tau_steps m n ->
weak_hat tau m n.
CoInductive bisimilar_conat : conat -> conat -> Prop :=
| bisim_conat : forall m n,
(forall l m', red l m m' ->
exists n', weak_hat l n n' /\ bisimilar_conat m' n') ->
(forall l n', red l n n' ->
exists m', weak_hat l m m' /\ bisimilar_conat m' n') ->
bisimilar_conat m n
I've proven various standard properties of this bisimilarity relation (equivalence relation, Park principle, some up-to techniques, etc.) so everything seems ok so far.
But now for my question: in a particular proof that two conats are bisimilar, it was quite difficult to satisfy the guardedness condition (for various reasons Park principle could not really be used, so that I had to prove bisimilarity directly). I therefore defined an auxiliary relation bisim_CF (defined below), and proved that the two conats are related in bisim_CF instead. The idea was that guardedness for the auxiliary relation was easily satisfied in the original proof (a bit like Ana Bove's technique for induction, perhaps); of course, there is now a separate proof obligation that bisim_CF is included in bisimularity - and that's the proof that I cannot do. Here is the definition of bisim_CF and the statement of the lemma:
CoInductive bisim_CF : conat -> conat -> Prop :=
| bisim_CF_bisim : forall m n,
bisimilar_conat m n ->
bisim_CF m n
| bisim_CF_prod : forall h m m' n n',
bisimilar_conat (h cozero) cozero ->
(forall i j, bisimilar_conat (h (coadd i j)) (coadd (h i) (h j))) ->
bisim_CF (h m) m' ->
bisim_CF (h n) n' ->
bisim_CF (h (coadd m n)) (coadd m' n').
Lemma bisim_CF_bisimilar : forall m n,
bisim_CF m n -> bisimilar_conat m n.
Graphically:
m ~ n h m CF m' h n CF n'
m CF n h (m + n) CF m' + n'
for any morphism h from conat -> conat (h 0 ~ 0 and h (i + j) ~ h i + h j).
Now, waving my hands, in the proof that this implies bisimularity, we proceed by coinduction, inversion on [bisim_CF], and then for the case of [bisim_CF_prod] we simply reason
h (m + n) ~ h m + h n ~ m' + n'
which uses an auxiliary lemma "add_bisim" that m + n ~ m' + n' if m ~ m' and n ~ n'; we need to reason that h m ~ m' and h n ~ n' "by coinduction". Unfortunately, this is not guarded, because the recursive calls will be used as arguments to "add_bisim" and to transitivity.
It is quite possible that bisim_CF was a very bad idea and that this way of trying to do the original proof is not possible, because bisim_CF is too large; but if that is the case, I cannot see it. However, I also keep getting stuck in [bisim_CF_bisimilar] -- the guardedness checker is never happy.
Any suggestions on how to proceed would be appreciated,
Edsko
- [Coq-Club] Need help with coinductive proof, Edsko de Vries
- Re: [Coq-Club] Need help with coinductive proof,
Nils Anders Danielsson
Edsko de Vries
- Re: [Coq-Club] Need help with coinductive proof, Nils Anders Danielsson
Edsko de Vries
- Re: [Coq-Club] Need help with coinductive proof, Keiko Nakata
- Message not available
Thorsten Altenkirch
Thorsten Altenkirch
- [Coq-Club] Re: Need help with coinductive proof, Nils Anders Danielsson
- Re: [Coq-Club] Re: Need help with coinductive proof, Keiko Nakata
- Re: [Coq-Club] Re: Need help with coinductive proof, Edsko de Vries
Thorsten Altenkirch
Thorsten Altenkirch
