coq-club - Re: [Coq-Club] Need help with coinductive proof
chronological Thread
  • To: Edsko de Vries <edskodevries AT gmail.com>
  • Cc: Coq Club <coq-club AT pauillac.inria.fr>, Agda List <agda AT lists.chalmers.se>
  • Subject: Re: [Coq-Club] Need help with coinductive proof
  • Date: Wed, 26 Aug 2009 11:59:24 +0100
P.S. I realize that my definition of ~ is not right, it is just extensional equality (bisimulation) on partial CoNats. The relation I want is rather:
data _≈_ : CoNat' → CoNat' → Set where
  zero : zero ≈ zero
  1+_ :  ∀ {m n} → ∞ (♭ m ≈ ♭ n) → 1+ m ≈ 1+ n
  τ :  ∀ {m n} → ∞ (♭ m ≈ ♭ n) → τ m ≈ τ n
  τl : ∀ {m n} → (♭ m ≈ n) → τ m ≈ n
  τr : ∀ {m n} → (m ≈ ♭ n) → m ≈ τ n
I.e. you can change the number of τs by a finite amount.
It is easy to show that it is a congruence for +'  but Agda doesn't seem to like my proof of transitivity (even though I am quite sure it is transitiv).
On 25 Aug 2009, at 18:31, Thorsten Altenkirch wrote:
Hi Edsko,
I am copying the Coq club back in - hope this is ok. I also cc it to the Agda list since I find it easier to answer the question in Agda (the background to the discussion can be found in the coq club archive).
Suppose we have a function (count f) on streams which returns (f x1 + f x2 + ...); then we want to prove a lemma that
 h . count f ~ count (h . f)
for any morphism h (except of course that we don't want to prove this for lists but prove it polytypically; for an informal statement of this lemma, see Hinze's habilitationsschrift, http://www.iai.uni-bonn.de/~ralf/publications/habilitation.pdf, p 102, Section 4.3.2).
It seems to me that to prove this you basically need to show that + preserves ~.
I implemented the relation I think you want to define in Agda using mixed induction/coinduction. First I define partial conatural numbers:
data CoNat' : Set where
  zero : CoNat'
  1+_ : ∞ CoNat' → CoNat'
  τ :  ∞ CoNat' → CoNat'
Here the recursive occurences marked with ∞ are coinductive. This is basically your type conat with the add constructor omitted. I call it CoNat' to make a difference to ordinary CoNat (without the τ ).
I define addition on partial coNaturals:
_+'_ : CoNat' → CoNat' → CoNat'
zero +' n = n
(1+ m) +' n = 1+ (♯ (♭ m) +' n)
(τ m) +' n = τ (♯ (♭ m) +' n)
To read this one has to know that ♭is "delay" and ♯ is "forcing". See our paper.
Instead of defining the equality directly I define a preorder corresponding to "more defined" (Agda allows to reuse constructors hence I use the same name for the congruences rules).
data _⊑_ :  CoNat' → CoNat' → Set where
  zero : zero ⊑ zero
  1+_ :  ∀ {m n} → ∞ (♭ m ⊑ ♭ n) → 1+ m ⊑ 1+ n
  τ :  ∀ {m n} → ∞ (♭ m ⊑ ♭ n) → τ m ⊑ τ n
  τl : ∀ {m n} → (♭ m ⊑ n) → τ m ⊑ n
This is a mixed inductive/coinductive definition, a see the paper which was already mentioned by Nisse:
The idea is that you can a less defined value may have a finite delay, hence here we use an inductive argument. However, we still need that 1+ and τ are congruences and hence their arguments have to be coinductive.
It is straightforward to show that ⊑ is a preorder:
refl⊑ : ∀ {m} → m ⊑ m
refl⊑ {zero} = zero
refl⊑ {1+ n} = 1+ (♯ (refl⊑ {♭ n}))
refl⊑ {τ n} = τ (♯ (refl⊑ {♭ n}))
trans⊑ : ∀ {l m n} → l ⊑ m → m ⊑ n → l ⊑ n
trans⊑ zero zero = zero
trans⊑ (1+ p) (1+ q) = 1+ (♯ trans⊑ (♭ p) (♭ q))
trans⊑ (τ p) (τ q) = τ (♯ trans⊑ (♭ p) (♭ q))
trans⊑ (τ p) (τl q) = τl (trans⊑ (♭ p) q)
trans⊑ (τl p) q = τl (trans⊑ p q)
Also it is not hard to show that +'  preserves ⊑:
cong+' : ∀ {m m' n n'} → m ⊑ m' → n ⊑ n' → (m +' n) ⊑ (m' +' n')
cong+' zero q = q
cong+' (1+ p) q = 1+ (♯ cong+' (♭ p) q)
cong+' (τ p) q = τ ((♯ cong+' (♭ p) q))
cong+' (τl p) q = τl (cong+' p q)
The relation ~ I think you want to define is simply the symmetric closure of ⊑ (and hence an equivalence relation). And cong+' implies that ~ is a congruence wrt +' which is sufficent to prove your result I think.
It shouldn't be too hard to translate this into Coq - the mixed inductive/coinductive definition you have to replace with a nested coinductive - inductive definition. You may have to spend some time to derive the appropriate induction and coinduction principles because they are not generated automatically afaik.
Or use Agda... :-)
Cheers,
Thorsten
P.S. Here is the Agda file:
This message has been checked for viruses but the contents of an attachment may still contain software viruses, which could damage your computer system: you are advised to perform your own checks. Email communications with the University of Nottingham may be monitored as permitted by UK legislation.
<Edsko-short.agda>
