- To: Edsko de Vries <edskodevries AT gmail.com>
- Cc: Coq Club <coq-club AT pauillac.inria.fr>, Agda List <agda AT lists.chalmers.se>
- Subject: Re: [Coq-Club] Need help with coinductive proof
- Date: Tue, 25 Aug 2009 18:31:14 +0100
Hi Edsko, I am copying the Coq club back in - hope this is ok. I also cc it to the Agda list since I find it easier to answer the question in Agda (the background to the discussion can be found in the coq club archive).
It seems to me that to prove this you basically need to show that + preserves ~. I implemented the relation I think you want to define in Agda using mixed induction/coinduction. First I define partial conatural numbers: data CoNat' : Set where zero : CoNat' 1+_ : ∞ CoNat' → CoNat' τ : ∞ CoNat' → CoNat' Here the recursive occurences marked with ∞ are coinductive. This is basically your type conat with the add constructor omitted. I call it CoNat' to make a difference to ordinary CoNat (without the τ ). I define addition on partial coNaturals: _+'_ : CoNat' → CoNat' → CoNat' zero +' n = n (1+ m) +' n = 1+ (♯ (♭ m) +' n) (τ m) +' n = τ (♯ (♭ m) +' n) To read this one has to know that ♭is "delay" and ♯ is "forcing". See our paper. Instead of defining the equality directly I define a preorder corresponding to "more defined" (Agda allows to reuse constructors hence I use the same name for the congruences rules). data _⊑_ : CoNat' → CoNat' → Set where zero : zero ⊑ zero 1+_ : ∀ {m n} → ∞ (♭ m ⊑ ♭ n) → 1+ m ⊑ 1+ n τ : ∀ {m n} → ∞ (♭ m ⊑ ♭ n) → τ m ⊑ τ n τl : ∀ {m n} → (♭ m ⊑ n) → τ m ⊑ n This is a mixed inductive/coinductive definition, a see the paper which was already mentioned by Nisse: The idea is that you can a less defined value may have a finite delay, hence here we use an inductive argument. However, we still need that 1+ and τ are congruences and hence their arguments have to be coinductive. It is straightforward to show that ⊑ is a preorder: refl⊑ : ∀ {m} → m ⊑ m refl⊑ {zero} = zero refl⊑ {1+ n} = 1+ (♯ (refl⊑ {♭ n})) refl⊑ {τ n} = τ (♯ (refl⊑ {♭ n})) trans⊑ : ∀ {l m n} → l ⊑ m → m ⊑ n → l ⊑ n trans⊑ zero zero = zero trans⊑ (1+ p) (1+ q) = 1+ (♯ trans⊑ (♭ p) (♭ q)) trans⊑ (τ p) (τ q) = τ (♯ trans⊑ (♭ p) (♭ q)) trans⊑ (τ p) (τl q) = τl (trans⊑ (♭ p) q) trans⊑ (τl p) q = τl (trans⊑ p q) Also it is not hard to show that +' preserves ⊑: cong+' : ∀ {m m' n n'} → m ⊑ m' → n ⊑ n' → (m +' n) ⊑ (m' +' n') cong+' zero q = q cong+' (1+ p) q = 1+ (♯ cong+' (♭ p) q) cong+' (τ p) q = τ ((♯ cong+' (♭ p) q)) cong+' (τl p) q = τl (cong+' p q) The relation ~ I think you want to define is simply the symmetric closure of ⊑ (and hence an equivalence relation). And cong+' implies that ~ is a congruence wrt +' which is sufficent to prove your result I think. It shouldn't be too hard to translate this into Coq - the mixed inductive/coinductive definition you have to replace with a nested coinductive - inductive definition. You may have to spend some time to derive the appropriate induction and coinduction principles because they are not generated automatically afaik. Or use Agda... :-) Cheers, Thorsten P.S. Here is the Agda file: This message has been checked for viruses but the contents of an attachment may still contain software viruses, which could damage your computer system: you are advised to perform your own checks. Email communications with the University of Nottingham may be monitored as permitted by UK legislation. |
Edsko-short.agda
Description: Binary data
- [Coq-Club] Need help with coinductive proof, Edsko de Vries
- Re: [Coq-Club] Need help with coinductive proof,
Nils Anders Danielsson
Edsko de Vries
- Re: [Coq-Club] Need help with coinductive proof, Nils Anders Danielsson
Edsko de Vries
- Re: [Coq-Club] Need help with coinductive proof, Keiko Nakata
- Message not available
- Re: [Coq-Club] Need help with coinductive proof, Thorsten Altenkirch
Thorsten Altenkirch
- [Coq-Club] Re: Need help with coinductive proof, Nils Anders Danielsson
- Re: [Coq-Club] Re: Need help with coinductive proof, Keiko Nakata
- Re: [Coq-Club] Re: Need help with coinductive proof, Edsko de Vries
Thorsten Altenkirch
Edsko de Vries
- Re: [Coq-Club] Need help with coinductive proof, Edsko de Vries
