coq-club - Re: [Coq-Club] Need help with coinductive proof
chronological Thread
  • To: Edsko de Vries <edskodevries AT gmail.com>
  • Cc: Coq Club <coq-club AT pauillac.inria.fr>, Agda List <agda AT lists.chalmers.se>
  • Subject: Re: [Coq-Club] Need help with coinductive proof
  • Date: Thu, 27 Aug 2009 15:03:08 +0100
Hi Edsko,
So far, so good. However, now consider the proof mentioned at the start. The standard bisimulation on conat's is defined like Thorsten did, except that I index the maximum delay (number of taus) using a natural number, rather than mixing coinduction and induction:
CoInductive bisimilar_conat : nat -> conat -> conat -> Prop :=
  | bisim_cozero : forall d,
      bisimilar_conat d cozero cozero
  | bisim_cosucc : forall d' d m n,
      bisimilar_conat d' m n ->
      bisimilar_conat d (cosucc m) (cosucc n)
  | bisim_tau : forall d' d m n,
      bisimilar_conat d (tau_conat m) (tau_conat n)
  | bisim_tau_left : forall d m n,
      bisimilar_conat d m n ->
      bisimilar_conat (S d) (tau_conat m) n
  | bisim_tau_right : forall d m n,
      bisimilar_conat (S d) m (tau_conat n).
However, (exists n:nat,bisimilar_conat n a b) is different from a ≈ b because there doesn't have to be a maximum delay (it is easy to construct a counterexample).
Isn't is possible to construct nested coinductive-inductive types in Coq?
Cheers,
Thorsten
This message has been checked for viruses but the contents of an attachment
may still contain software viruses, which could damage your computer system:
you are advised to perform your own checks. Email communications with the
University of Nottingham may be monitored as permitted by UK legislation.
