coq-club - [Coq-Club] mysterious failure of termination-checking algorithm
chronological Thread
  • To: Coq List <coq-club AT pauillac.inria.fr>
  • Subject: [Coq-Club] mysterious failure of termination-checking algorithm
  • Date: Sun, 20 Sep 2009 13:10:51 -0400
  • Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:sender:date:x-google-sender-auth:message-id:subject :from:to:content-type; b=GcMuLJpANG3XTLGthBvtt7tuhlpH0/O0Tr+7mzk+4C6cOF3l58Eeel7yxX0wGoUdLr eHR/BYB8QaCWFi9+gAQQ+NahTuOndPaTSXwnrRzYgL79do6a14yZ7n24BCK5t0RCZMp+ /YiBJiP4V5+FbxdNznDcvyzb5UlaZPmRWk2ag=
I have a little development that defines freely generated terms of a
signature of symbols with arities.  It uses vectors to ensure that
terms are well-formed.  (I know this was also done in the CoLoR
library.)  Additionally, I want to define terms with holes, so I use a
derived signature with an option type for the one extra symbol.  Now
let's say I want to write a function over these contexts to determine
whether a hole symbol appears in a term.  How does one do this?
You can step through the code below and see that my first attempt,
"no_hole", fails the termination-checker, even though the extremely
similar function "all_term" passes it.  They're so similar, in fact,
that "no_hole" is actually just a specific instance of "all_term", as
you can see from the definition of "no_hole_from_all_term".  So why
does the definition of "no_hole" fail???
Now you ask, "why do I care if I already found a way to define the
function?"  OK, well tell me now how to define a function that tests
whether exactly one hole symbol appears in a term...
 - Aaron
---- Coq code ----
Set Implicit Arguments.
Inductive vector (A: Type): nat -> Type :=
| vnil: vector A O
| vcons: forall len, A -> vector A len -> vector A (S len).
Implicit Arguments vnil [A].
Definition vall (A: Type) (P: A -> Prop)
: forall len: nat, vector A len -> Prop :=
  fix vall' (len: nat) (xs: vector A len) {struct xs}: Prop :=
    match xs in vector _ len' return Prop with
    | vnil => True
    | vcons len1 a xs1 => P a /\ vall' len1 xs1
    end.
Record signature: Type := mk_signature {
  symbol: Set;
  arity: symbol -> nat
Inductive term (S: signature): Type :=
| term_app: forall a: symbol S, vector (term S) (arity S a) -> term S.
Fixpoint all_term
  (S: signature) (P: symbol S -> Prop) (t: term S) {struct t}: Prop :=
  match t with
  | term_app a ts => P a /\ vall (@all_term S P) ts
  end.
Definition context_signature (S: signature): signature :=
  let context_symbol := option (symbol S) in
  let context_arity a :=
    match a with
    | Some a1 => arity S a1
    | None => 0
    end
  in
  @mk_signature context_symbol context_arity.
Definition context (S: signature): Type :=
  term (context_signature S).
Fixpoint no_hole (S: signature) (c: context S) {struct c}: Prop :=
  match c with
  | term_app (Some a) cs => vall (@no_hole S) cs
  | term_app None _ => False
  end.
Definition no_hole_from_all_term (S: signature): context S -> Prop :=
  let isnt_hole (a: symbol (context_signature S)): Prop :=
    match a with
    | Some _ => True
    | None => False
    end
  in
  all_term isnt_hole.
