coq-club - Re: [Coq-Club] mysterious failure of termination-checking algorithm
chronological Thread
  • To: Coq List <coq-club AT pauillac.inria.fr>
  • Subject: Re: [Coq-Club] mysterious failure of termination-checking algorithm
  • Date: Tue, 22 Sep 2009 11:04:21 -0400
Hi Stéphane,
Le 22 sept. 09 à 09:54, Stéphane Lescuyer a écrit :
Hi Bruno,
Thank you for your explanation, this makes perfect sense indeed, once
you know what's going on under the hood. The issue here is how do you
know the expression which is actually fed to the typechecker ? My
error message only shows the typing context and not the whole fixpoint
body :
Recursive definition of no_hole is ill-formed.
In environment
no_hole : forall S : signature, context S -> Prop
S : signature
c : context S
Recursive call to no_hole has principal argument equal to
"a1" instead of cs.
So I can actually see the two cs, cs0 and the corresponding a, a0
which can help understand what's going on, but is there any option
that I'm unaware of which displays the whole fixpoint body ? That
would be pretty useful in such circumstances.
I added this info to the message in the trunk, it will be part of the
next version.
-- Matthieu
