- To: Aaron Bohannon <bohannon AT cis.upenn.edu>
- Cc: Coq List <coq-club AT pauillac.inria.fr>
- Subject: Re: [Coq-Club] mysterious failure of termination-checking algorithm
- Date: Sun, 20 Sep 2009 13:53:43 -0400 (EDT)
Interestingly, the following does work:
Fixpoint no_hole (S: signature) (c: context S) {struct c}: Prop :=
match c with
| term_app a cs => match a with
(Some _) => vall (@no_hole S) cs
| None => False
end
end.
On Sun, 20 Sep 2009, Aaron Bohannon wrote:
I have a little development that defines freely generated terms of a
signature of symbols with arities. It uses vectors to ensure that
terms are well-formed. (I know this was also done in the CoLoR
library.) Additionally, I want to define terms with holes, so I use a
derived signature with an option type for the one extra symbol. Now
let's say I want to write a function over these contexts to determine
whether a hole symbol appears in a term. How does one do this?
You can step through the code below and see that my first attempt,
"no_hole", fails the termination-checker, even though the extremely
similar function "all_term" passes it. They're so similar, in fact,
that "no_hole" is actually just a specific instance of "all_term", as
you can see from the definition of "no_hole_from_all_term". So why
does the definition of "no_hole" fail???
Now you ask, "why do I care if I already found a way to define the
function?" OK, well tell me now how to define a function that tests
whether exactly one hole symbol appears in a term...
- Aaron
---- Coq code ----
Set Implicit Arguments.
Inductive vector (A: Type): nat -> Type :=
| vnil: vector A O
| vcons: forall len, A -> vector A len -> vector A (S len).
Implicit Arguments vnil [A].
Definition vall (A: Type) (P: A -> Prop)
: forall len: nat, vector A len -> Prop :=
fix vall' (len: nat) (xs: vector A len) {struct xs}: Prop :=
match xs in vector _ len' return Prop with
| vnil => True
| vcons len1 a xs1 => P a /\ vall' len1 xs1
end.
Record signature: Type := mk_signature {
symbol: Set;
arity: symbol -> nat
Inductive term (S: signature): Type :=
| term_app: forall a: symbol S, vector (term S) (arity S a) -> term S.
Fixpoint all_term
(S: signature) (P: symbol S -> Prop) (t: term S) {struct t}: Prop :=
match t with
| term_app a ts => P a /\ vall (@all_term S P) ts
end.
Definition context_signature (S: signature): signature :=
let context_symbol := option (symbol S) in
let context_arity a :=
match a with
| Some a1 => arity S a1
| None => 0
end
in
@mk_signature context_symbol context_arity.
Definition context (S: signature): Type :=
term (context_signature S).
match c with
| term_app (Some a) cs => vall (@no_hole S) cs
| term_app None _ => False
end.
Definition no_hole_from_all_term (S: signature): context S -> Prop :=
let isnt_hole (a: symbol (context_signature S)): Prop :=
match a with
| Some _ => True
| None => False
end
in
all_term isnt_hole.
Bug reports: http://logical.saclay.inria.fr/coq-bugs
Archives: http://pauillac.inria.fr/pipermail/coq-club
http://pauillac.inria.fr/bin/wilma/coq-club
Info: http://pauillac.inria.fr/mailman/listinfo/coq-club
Russell O'Connor <http://r6.ca/>
``All talk about `theft,''' the general counsel of the American Graphophone
Company wrote, ``is the merest claptrap, for there exists no property in
ideas musical, literary or artistic, except as defined by statute.''
- [Coq-Club] mysterious failure of termination-checking algorithm, Aaron Bohannon
- Re: [Coq-Club] mysterious failure of termination-checking algorithm, roconnor
Aaron Bohannon
Stéphane Lescuyer
Bruno Barras
Stéphane Lescuyer
- Re: [Coq-Club] mysterious failure of termination-checking algorithm, Matthieu Sozeau
Stéphane Lescuyer
Bruno Barras
Stéphane Lescuyer
Aaron Bohannon
