coq-club - Re: [Coq-Club] mysterious failure of termination-checking algorithm
chronological Thread
  • To: St�phane Lescuyer <stephane.lescuyer AT inria.fr>
  • Cc: Aaron Bohannon <bohannon AT cis.upenn.edu>, roconnor AT theorem.ca, Coq List <coq-club AT pauillac.inria.fr>
  • Subject: Re: [Coq-Club] mysterious failure of termination-checking algorithm
  • Date: Tue, 22 Sep 2009 12:22:03 +0200
Stéphane Lescuyer a écrit :
Note that the intermediary pattern variable 'a' (introduced
explicitely by Russell's variant, and not in the original version)
actually appears in the arguments of vall. If you try a version of
terms where the length does not depend on the symbol, say :
Record signature : Type := mk_signature  {
  symbol : Set;
  arity : nat
Inductive term (S: signature): Type :=
| term_app: forall a: symbol S, vector (term S) (arity S) -> term S.
Then your original definition works fine.
I don't know quite what to make of it, but this definitely looks like
a bug and gives a good hint as to where to start investigating.
Stephane
Hi,
This is not exactly a bug.
match tries to be smart when matching on constructor arguments upon which further arguments depend. Here, the type of cs depends on a. When you match on a (by deep matching on c), the match macro automatically generalizes cs so that its type gets more precise. As the error message says, the expanded fixpoint body (of Aaron's attempt) is:
fun (S : signature) (c : context S) =>
 match c with
 | term_app a0 cs =>
     match a0 with
     | Some a =>
         fun cs0 =>
          @vall (context S) (no_hole S)
           (arity (context_signature S) (@Some (symbol S) a)) cs0
     | None => fun _ => False
     end cs
 end
Unfortunately, this generalization-match-then-introduction is too much for the termination-checker: it cannot see that cs0 is actually the same vector as cs.
By splitting the match as Russell did, this automatic generalization is not done, so recursive calls are really made on cs, which is accepted.
If you really need the most precise type for cs (this is not the case here), then you could make the match on a0 generate equality (a0 = Some a) and rewrite the type of cs (the guard condition knows that (match e return ... with refl_equal => cs end) has the same size as cs). I must admit this is quite painful to do by hand.
Hope this helps,
Bruno Barras.
