- To: Coq List <coq-club AT pauillac.inria.fr>
- Subject: [Coq-Club] Pattern matching on vectors
- Date: Thu, 08 Oct 2009 18:20:35 -0400
Hi,
I'm trying to prove some simple theorems using types defined in terms of vectors. I'm getting suck because I'm not sure how to destruct a vector when there are constraints on its length.
Vectors are defined as follows:
Set Implicit Arguments.
Inductive vector (A: Type): nat -> Type :=
| vnil: vector A O
| vcons: forall len, A -> vector A len -> vector A (S len).
Implicit Arguments vnil [A].
And I would like to prove, for instance, this lemma:
Lemma openVector: forall A n (v: vector A (S n)),
exists a, exists v0, v = vcons a v0.
The problem---as I understand it---is that induction (elim/destruct/generalized induction...) on v produces goals that are ill-typed. For instance,
exists a, exists v0, vnil = vcons a v0
Note that the left hand side of the equality has type (vector A 0) and the right hand side has type (vector A (S _)). I tried using John Major equality. This let me take a small step forward, but didn't enable real progress.
Any tips?
Best,
Jeff Vaughan
- [Coq-Club] Pattern matching on vectors, Jeff Vaughan
- Message not available
- Re: [Coq-Club] Pattern matching on vectors, Jeff Vaughan
- Re: [Coq-Club] Pattern matching on vectors, Adam Chlipala
Laurent Théry
Benedikt . AHRENS
- Re: [Coq-Club] Pattern matching on vectors, Matthieu Sozeau
- Re: [Coq-Club] Pattern matching on vectors for dummies, Jean-Francois Monin
Benedikt . AHRENS
- Re: [Coq-Club] Pattern matching on vectors, Adam Koprowski
