- To: Benedikt.AHRENS AT unice.fr
- Cc: Laurent Th�ry <Laurent.Thery AT sophia.inria.fr>, Coq List <coq-club AT pauillac.inria.fr>
- Subject: Re: [Coq-Club] Pattern matching on vectors
- Date: Fri, 09 Oct 2009 17:45:28 -0400
I haven't tried this yet, but Frederic Blanqui and Adam Koprowski pointed me to the CoLoR library which has lemmas and tactics for unfolding vectors (http://color.inria.fr/doc/CoLoR.Util.Vector.VecUtil.html#VSntac). You may be able to write tactic based on theirs which handles both theorems.
Best,
Jeff
wrote:
Hello,
for the complementary theorem about vectors of length 0 (code at the
bottom), Adam's suggestion can be adopted [1], whereas a proof similar
to Laurent's [2] fails, since the abstraction in the inversion step
gives an ill-typed term.
Is there a way to prove the lemma by tactics anyway?
Greetings
ben
[1]
Definition is_vnil (A:Set) (v:vector A 0):
v = vnil :=
match v in vector _ N return
match N return vector A N -> Prop with
| 0 => fun v0 => v0 = vnil
| S p => fun _ => True
end v with
| vnil => refl_equal _
| vcons _ _ _ => I
end.
[2]
Lemma is_nil: forall A (v:vector A 0),
v = vnil.
Proof.
intros A v.
change (
(fun n => match n as n1 return vector A n1 -> Prop with
| 0 => fun v => v = vnil
end) 0 v).
dependent inversion v.
Error: Abstracting over the terms "0" and "v" leads to a term
"fun (n : nat) (v : vector A n) =>
(fun n0 : nat =>
match n0 as n1 return (vector A n1 -> Prop) with
| 0 => fun v0 : vector A n => v0 = vnil
| S p => fun _ : vector A (S p) => True
end) n v" which is ill-typed.
Laurent Théry wrote:
Hi,
yep you have to break the dependance in the equality.
Adam's idea but with tactic:
Lemma openVector: forall A n (v: vector A (S n)),
exists a, exists v0, v = vcons a v0.
intros A n v.
change
((fun n: nat => match n return vector A n -> Prop with
O => fun _ => True (* what you want *)
| S n1 => fun v =>
exists a : A, exists v0 : vector A n1, v = vcons a v0
end) (S n) v).
dependent inversion v as [|n1 a1 v1].
exists a1; exists v1; auto.
Qed.
Bug reports: http://logical.saclay.inria.fr/coq-bugs
Archives: http://pauillac.inria.fr/pipermail/coq-club
http://pauillac.inria.fr/bin/wilma/coq-club
Info: http://pauillac.inria.fr/mailman/listinfo/coq-club
- [Coq-Club] Pattern matching on vectors, Jeff Vaughan
- Message not available
- Re: [Coq-Club] Pattern matching on vectors, Jeff Vaughan
- Re: [Coq-Club] Pattern matching on vectors, Adam Chlipala
Laurent Théry
Benedikt . AHRENS
- Re: [Coq-Club] Pattern matching on vectors, Matthieu Sozeau
- Re: [Coq-Club] Pattern matching on vectors for dummies, Jean-Francois Monin
Benedikt . AHRENS
- Re: [Coq-Club] Pattern matching on vectors, Adam Koprowski
