coq-club - Re: [Coq-Club] Pattern matching on vectors
chronological Thread
  • To: Ryan Wisnesky <ryan AT cs.harvard.edu>, Coq List <coq-club AT pauillac.inria.fr>
  • Subject: Re: [Coq-Club] Pattern matching on vectors
  • Date: Thu, 08 Oct 2009 18:59:55 -0400
Thanks Ryan!
Matthieu Sozeau just replied off list and suggested using
dependent destruction/induction. Like your proof these tactics also use JMeq and import an axiom.
Is there any reason to be wary of the JMeq_eq axiom? Is it possible to prove such a theorem without JMeq?
Also, when you suggest a fixpoint based version of vectors, do you mean something like the following?
Fixpoint vec' (A: Type) (n: nat) : Type :=
  match n with
    O => unit
  | S m => A * vec' A m
  end.
Best,
Jeff
Ryan Wisnesky wrote:
Personally, I think the real moral of the story here is to avoid indexing inductive types with terms. Here's the first proof I could think of:
Inductive vector (A: Type): nat -> Type :=
 | vnil: vector A O
 | vcons: forall len, A -> vector A len -> vector A (S len).
Set Implicit Arguments.
Require Import JMeq.
 Lemma openVector: forall A n (v: vector A (S n)),
   exists a, exists v0, v = vcons A n a v0.
 Proof.
  intros.
  refine (match v as v' in vector _ n' return S n = n' -> JMeq v v' ->
            exists a : A, exists v0 : vector A n, v = vcons A n a v0
            with
            | vnil => _
            | vcons n a v0 => _
          end (refl_equal (S n)) (JMeq_refl v)).
  intros. discriminate. (* first case is impossible *)
  intros. assert (n = n0). congruence. subst. clear H.
  apply JMeq_eq in H0. (* use jmeq axiom *)
  eauto.
Qed.
What's happening here is case analysis on v, just like you wanted, but there an "as" and "in" clause that tells Coq explicitly how to handle the dependency. The tactics don't generally deal with this well so you may need to write proof terms manually like this. I'd recommend moving to a fixpoint version of vector instead.
On Oct 8, 2009, at 6:20 PM, Jeff Vaughan wrote:
Hi,
I'm trying to prove some simple theorems using types defined in terms of vectors. I'm getting suck because I'm not sure how to destruct a vector when there are constraints on its length.
Vectors are defined as follows:
 | vnil: vector A O
 Implicit Arguments vnil [A].
And I would like to prove, for instance, this lemma:
   exists a, exists v0, v = vcons a v0.
The problem---as I understand it---is that induction (elim/destruct/generalized induction...) on v produces goals that are ill-typed. For instance,
 exists a, exists v0, vnil = vcons a v0
Note that the left hand side of the equality has type (vector A 0) and the right hand side has type (vector A (S _)). I tried using John Major equality. This let me take a small step forward, but didn't enable real progress.
Any tips?
Best,
Jeff Vaughan
Bug reports: http://logical.saclay.inria.fr/coq-bugs
Archives: http://pauillac.inria.fr/pipermail/coq-club
        http://pauillac.inria.fr/bin/wilma/coq-club
Info: http://pauillac.inria.fr/mailman/listinfo/coq-club
