coq-club - Re: [Coq-Club] Pattern matching on vectors
chronological Thread
  • To: Jeff Vaughan <jeff AT seas.harvard.edu>
  • Cc: Coq List <coq-club AT pauillac.inria.fr>
  • Subject: Re: [Coq-Club] Pattern matching on vectors
  • Date: Fri, 9 Oct 2009 10:30:05 +0200
  • Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:in-reply-to:references:from:date:message-id:subject:to :cc:content-type; b=Th6c74IbK/nqdTThVYHaJx6DXlcPZwKGrwxfqjxxkZ33HDiladMp/IZIyoXfMYfUjb z8kHFiM/AlggksUNhmhVIv+0uHrJIDQOfFkcwDvk7ro0PamDQCvXJNyu8BKSZYYuz7lm Bx+t+c2GRhTYGw5cu1Rr1tUw8Tax8YMBPmv7k=
  Dear Jeff,
  I'd just like to point out that the CoLoR library has a rich set of results on vectors (as an extension to Coq's stdlib). You'll also find Vsn_eq there from which your lemma trivially follows. Hope that helps.
  Cheers,
   Adam
On Fri, Oct 9, 2009 at 00:20, Jeff Vaughan <jeff AT seas.harvard.edu> wrote:
Hi,
I'm trying to prove some simple theorems using types defined in terms of vectors.  I'm getting suck because I'm not sure how to destruct a vector when there are constraints on its length.
Vectors are defined as follows:
 Set Implicit Arguments.
 Inductive vector (A: Type): nat -> Type :=
 | vnil: vector A O
 | vcons: forall len, A -> vector A len -> vector A (S len).
 Implicit Arguments vnil [A].
And I would like to prove, for instance, this lemma:
 Lemma openVector: forall A n (v: vector A (S n)),
   exists a, exists v0, v = vcons a v0.
The problem---as I understand it---is that induction (elim/destruct/generalized induction...) on v produces goals that are ill-typed.  For instance,
 exists a, exists v0, vnil = vcons a v0
Note that the left hand side of the equality has type (vector A 0) and the right hand side has type (vector A (S _)).  I tried using John Major equality.  This let me take a small step forward, but didn't enable real progress.
Any tips?
Best,
Jeff Vaughan
Bug reports: http://logical.saclay.inria.fr/coq-bugs
Archives: http://pauillac.inria.fr/pipermail/coq-club
        http://pauillac.inria.fr/bin/wilma/coq-club
Info: http://pauillac.inria.fr/mailman/listinfo/coq-club
Adam.Koprowski AT gmail.com, http://www.cs.ru.nl/~Adam.Koprowski
The difference between impossible and possible
lies in determination (Tommy Lasorda)
