- To: Coq Club <coq-club AT pauillac.inria.fr>
- Subject: [Coq-Club] another question (cont.)
- Date: Tue, 13 Oct 2009 13:57:03 -0400
Actually,
Check eq S0 P0 .
produces
S0 = P0
: Prop
Is this a bug?
V.
On Oct 13, 2009, at 1:49 PM, Vladimir Voevodsky wrote:
In the following sequence of instructions:
Axiom f5 : Set -> nat .
Axiom P0 : Prop .
Axiom S0 : Set .
Check f5 P0 .
Check eq P0 S0 .
The last two produce the following reactions:
f5 P0
: nat
and
Error: The term "S0" has type "Set" while it is expected to have type "Prop".
respectively.
Why does f5 treat Prop as a subtype of Set but eq does not?
V.
Bug reports: http://logical.saclay.inria.fr/coq-bugs
Archives: http://pauillac.inria.fr/pipermail/coq-club
http://pauillac.inria.fr/bin/wilma/coq-club
Info: http://pauillac.inria.fr/mailman/listinfo/coq-club
- Re: [Coq-Club] an inductive types question, (continued)
- Re: [Coq-Club] an inductive types question, Vladimir Voevodsky
- Re: [Coq-Club] an inductive types question, Adam Chlipala
- Re: [Coq-Club] an inductive types question, AUGER Cédric
- Re: [Coq-Club] an inductive types question, André Hirschowitz
- Re: [Coq-Club] an inductive types question, Dan Doel
- [Coq-Club] another question (Prop as a subtype of Set), Vladimir Voevodsky
- [Coq-Club] another question (cont.), Vladimir Voevodsky
- Re: [Coq-Club] another question (cont.), Taral
- [Coq-Club] About extraction and mutual recursion, AUGER Cédric
- [Coq-Club] Typo on coq manual, AUGER
- Re: [Coq-Club] Typo on coq manual, Pierre Letouzey
- Re: [Coq-Club] another question (Prop as a subtype of Set), Matthieu Sozeau
- [Coq-Club] another inductive types question, Vladimir Voevodsky
