coq-club - [Coq-Club] another question (Prop as a subtype of Set)
chronological Thread
  • To: Coq Club <coq-club AT pauillac.inria.fr>
  • Subject: [Coq-Club] another question (Prop as a subtype of Set)
  • Date: Tue, 13 Oct 2009 13:49:08 -0400
In the following sequence of instructions:
Axiom f5 : Set -> nat .
Axiom P0 : Prop .
Axiom S0 : Set .
Check f5 P0 .
Check eq P0 S0 .
The last two produce the following reactions:
f5 P0
     : nat
and
Error: The term "S0" has type "Set" while it is expected to have type "Prop".
respectively.
Why does f5 treat Prop as a subtype of Set but eq does not?
V.
