- To: Vladimir Voevodsky <vladimir AT ias.edu>
- Cc: Coq Club <coq-club AT pauillac.inria.fr>
- Subject: Re: [Coq-Club] an inductive types question
- Date: Sat, 10 Oct 2009 21:02:31 -0400
Vladimir Voevodsky wrote:
Suppose for example that T= Prop. Then, a function from I1 to T should be a triple (P_1, P_2, prf) where P_1, P_2: Prop and prf: P_1 <-> P_2 is a proof of their equivalence.
If what you care about is "functions over T," then why not go directly to defining a type of "functions over T"? It's easy to define a record type whose values are exactly the triples of the form you describe.
I'm still pretty confused as to what you're trying to do, and I expect I'm not alone, so context that is about applications, not just "algebraic structures," would be a good thing to provide if you want further help.
- Re: [Coq-Club] Type hierarchy, (continued)
- Re: [Coq-Club] Type hierarchy, Hugo Herbelin
- Re: [Coq-Club] Type hierarchy, Adam Chlipala
- Re: [Coq-Club] Type hierarchy, Jean-Francois Dufourd
- [Coq-Club] an inductive types question, Vladimir Voevodsky
- Re: [Coq-Club] an inductive types question, Adam Chlipala
- Re: [Coq-Club] an inductive types question, Vladimir Voevodsky
- Re: [Coq-Club] an inductive types question, Thorsten Altenkirch
- Re: [Coq-Club] an inductive types question, AUGER Cédric
- Re: [Coq-Club] an inductive types question, André Hirschowitz
- Re: [Coq-Club] an inductive types question, Dan Doel
- [Coq-Club] another question (Prop as a subtype of Set), Vladimir Voevodsky
- [Coq-Club] another question (cont.), Vladimir Voevodsky
- Re: [Coq-Club] another question (cont.), Taral
