- To: Vladimir Voevodsky <vladimir AT ias.edu>
- Cc: Coq Club <coq-club AT pauillac.inria.fr>
- Subject: Re: [Coq-Club] an inductive types question (2)
- Date: Tue, 20 Oct 2009 19:44:30 +0800
On Tue, 2009-10-20 at 13:04 -0400, Vladimir Voevodsky wrote:
> (cont.) Does it imply that in the empty context it is impossible to
> define a function (nat -> nat) -> nat which maps f to its minimal value?
> V.
Indeed. If you could define such a function, than you could take any
\Pi^0_1 sentence P (a proposition of one parameter n that is decidable
for each instance of that parameter), and define a function f:nat->nat
in Coq such that:
f n reduces to (S 0) if the proposition P(n) is true
f n reduces to 0 if the proposition P(n) is false
taking your min:(nat->nat)->nat function, we could decide of the truth
of such a sentence: it suffices to test whether (min f) reduces to 0 or
to 1 which it necessarily does by the previous argument. This would
allow us to solve the halting problem.
Hope this helps,
Cody
> On Oct 20, 2009, at 6:56 AM, Cody Roux wrote:
> > On Tue, 2009-10-20 at 12:43 -0400, Vladimir Voevodsky wrote:
> >> (cont.) Is it also true that any closed term of type nat reduces
> >> to a
> >> term of the form S ... S O ?
> >> V.
> > Also true, if as Adam has said, you work in a system without (non
> > computational) axioms. This can be generalized to all inductive types,
> > though one must notice that in the presence of dependent types, some
> > instances of the inductive types may be empty e.g.
> > Inductive ZeroEmpty: nat->Type:=
> > |Notzero: forall n, ZeroEmpty (S n)
> > In this case (ZeroEmpty 0) is uninhabited. Nevertheless, every term of
> > type (ZeroEmpty 0) in the empty context (in this case there are no
> > such
> > terms) does reduce to (Notzero t).
> > Cody
> >> On Oct 20, 2009, at 6:38 AM, Cody Roux wrote:
> >>> On Tue, 2009-10-20 at 12:24 -0400, Vladimir Voevodsky wrote:
> >>>> Given an inductive type such as
> >>>> Inductive two_el := el_1 | el_2 .
> >>>> are there closed terms of type two_el which do not reduce to either
> >>>> el_1 or el_2 ?
> >>> No. This can be deduced from the strong normalisation property of
> >>> the
> >>> underlying calculus of Coq (CIC+Predicative Set+Universes), combined
> >>> with the Inversion Property: It is easy to show by case analysis
> >>> that
> >>> any term in normal form and in the empty context of type two_el must
> >>> be
> >>> one of the constructors of this type. This can be compared with the
> >>> disjunction property which states:
> >>> If t is a term of type A\/B in the empty context then t reduces to
> >>> inl t1 or to inr t2
> >>> Which happens to be quite a desirable property in constructive
> >>> mathematics.
> >>> Cheers
> >>> Cody
- Re: [Coq-Club] A not so FSet specific question about destruction, (continued)
Guillaume Melquiond
- Re: [Coq-Club] A not so FSet specific question about destruction, Stéphane Lescuyer
- Re: [Coq-Club] A not so FSet specific question about destruction, Matthieu Sozeau
- [Coq-Club] an inductive types question (2),
Vladimir Voevodsky
- Re: [Coq-Club] an inductive types question (2), Adam Chlipala
Cody Roux
Vladimir Voevodsky
Cody Roux
Vladimir Voevodsky
- Re: [Coq-Club] an inductive types question (2), muad
- Re: [Coq-Club] an inductive types question (2), Cody Roux
Vladimir Voevodsky
Cody Roux
Vladimir Voevodsky
Guillaume Melquiond
