coq-club - [Coq-Club] Re: [Agda] Agda with excluded middle is inconsistent
chronological Thread
  • From: Noam Zeilberger <noam.zeilberger AT gmail.com>
  • To: Thorsten Altenkirch <txa AT cs.nott.ac.uk>
  • Cc: Chung Kil Hur <Chung-Kil.Hur AT pps.jussieu.fr>, coq-club AT inria.fr, Agda mailing list <agda AT lists.chalmers.se>
  • Subject: [Coq-Club] Re: [Agda] Agda with excluded middle is inconsistent
  • Date: Thu, 7 Jan 2010 17:24:30 +0100
  • Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:in-reply-to:references:date:message-id:subject:from:to :cc:content-type:content-transfer-encoding; b=e+YsCzo4F6D3izRP03pzeJdDrQ8Mh4s804AoFPyTDdZpklEOnapYqe4CIwlqS7sYCn iyNOvWhdSo2MVDJjNLQjAnYygSLYuRlY8RATZh5GztEu+x0msZMqCFSdFUVxUfSTFG2c bDcnrJF7zX9TZB8g0O4wlSd+nr//50Pz3WTec=
  • List-archive: <http://lists.chalmers.se/pipermail/agda>
  • List-id: Agda implementors and users group <agda.lists.chalmers.se>
  • Resent-date: Tue, 19 Jan 2010 15:50:25 +0100
  • Resent-from: Hugo Herbelin <Hugo.Herbelin AT inria.fr>
  • Resent-message-id: <20100119145025.GB17061 AT pirogue.inria.fr>
  • Resent-to: coq-club AT inria.fr
On Thu, Jan 7, 2010 at 4:15 PM, Thorsten Altenkirch
 wrote:
>> ...I'm not sure about this expansion, and the analogy.  I think the
>> question is whether we view the declaration of type constructors in
>> the same way that we view the declaration of term constructors (i.e.,
>> as stipulating a new way of constructing things, in this case
>> inhabitants of Set).  If we do, then type constructors are by
>> definition injective.
> I don't see the analogy. A term constructor is injective because an
> inductive type is freely generated from constructors. Indeed, we can show
> that the structure map of an initial algebra is an isomorphism and hence
> injective. However the universe of sets is not freely constructed from type
> constructors but they are really definitions.
But freeness ("inductive type = no confusion + no junk") is only a
sufficient condition, right?  Injectivity = no confusion.
> We should justify principles like this (i.e. all type constructors are
> injective) by a semantic explanation or by a translation into a well
> understood core language e.g. (extensional) Marttin-Loef Type Theory with
> W-types and universes. I don't know any such explanation which would
> justify this principle. Moreover, Chung's example shows that this is not
> possible (without giving up something else) since pure type theory is
> consistent with EM.
Agreed that there should be a convincing explanation, but again, I do
think there is a strong intuition behind the principle (what Dan Doel
and I were getting at), and the fact that it plays an important role
in typechecking suggests that we shouldn't jump to conclusions.  I am
not sure that Agda should be conservative over classical mathematics:
it seems there is a fundamental tension between exploiting the full
power of a constructive type theory and upholding the fictions of
classical mathematics.  Chung-Kil's paradox shows that you can't
reason classically in Agda just by adding the law of excluded middle
-- okay, so don't do it that way.
Could you explain what you meant by: "Also while we may accept that
extensions of Type Theory may be anticlassical, we should expect that
core Type Theory is consistent with EM."?
Noam
_______________________________________________
Agda mailing list
Agda AT lists.chalmers.se
https://lists.chalmers.se/mailman/listinfo/agda
