- From: David Wahlstedt <david.wahlstedt AT gmail.com>
- To: Noam Zeilberger <noam.zeilberger AT gmail.com>
- Cc: Chung Kil Hur <Chung-Kil.Hur AT pps.jussieu.fr>, coq-club AT inria.fr, Agda mailing list <agda AT lists.chalmers.se>
- Subject: [Coq-Club] Re: [Agda] Agda with excluded middle is inconsistent
- Date: Fri, 8 Jan 2010 11:18:53 +0100
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:in-reply-to:references:date:message-id:subject:from:to :cc:content-type; b=bB+c4Ki8B9y8DU9pvod1rLjDpCVIxa5UsyiX9owvv8utVMCp8rmQSs6ohc0EwxSFAh z7d8264RYGdnLfgMwKfJ1g9FnMkDmKoa21iUAkxZcMX6QFUJ+5VQTcLIixDRntk9Frvo W20CseprPAlsykMTj8WJ2fWwia8xRSWbacGGo=
- List-archive: <http://lists.chalmers.se/pipermail/agda>
- List-id: Agda implementors and users group <agda.lists.chalmers.se>
- Resent-date: Tue, 19 Jan 2010 15:51:59 +0100
- Resent-from: Hugo Herbelin <Hugo.Herbelin AT inria.fr>
- Resent-message-id: <20100119145159.GF17061 AT pirogue.inria.fr>
- Resent-to: coq-club AT inria.fr
Hi,
I have read through the two threads on this topic, and:
_______________________________________________Sorry if I mention something that is "too basic" / "naive", but, to clarify even more on Thorstens remark about the compatibility of MLTT with EM, it should be recalled that ~~(P \/ ~P) is a theorem even in very basic intuitionistic logic.
So if we add something to our system such that ~(P \/ ~P) becomes a theorem, we really have got an inconsistent system, without having to assume anything non-constructive. Or have I missed something ?
Best regards,
David Wahlstedt
On Thu, Jan 7, 2010 at 5:24 PM, Noam Zeilberger <noam.zeilberger AT gmail.com> wrote:
On Thu, Jan 7, 2010 at 4:15 PM, Thorsten Altenkirch <txa AT cs.nott.ac.uk> wrote:But freeness ("inductive type = no confusion + no junk") is only a
>> ...I'm not sure about this expansion, and the analogy. I think the
>> question is whether we view the declaration of type constructors in
>> the same way that we view the declaration of term constructors (i.e.,
>> as stipulating a new way of constructing things, in this case
>> inhabitants of Set). If we do, then type constructors are by
>> definition injective.
> I don't see the analogy. A term constructor is injective because an inductive type is freely generated from constructors. Indeed, we can show that the structure map of an initial algebra is an isomorphism and hence injective. However the universe of sets is not freely constructed from type constructors but they are really definitions.
sufficient condition, right? Injectivity = no confusion.
Agreed that there should be a convincing explanation, but again, I do
> We should justify principles like this (i.e. all type constructors are injective) by a semantic explanation or by a translation into a well understood core language e.g. (extensional) Marttin-Loef Type Theory with W-types and universes. I don't know any such explanation which would justify this principle. Moreover, Chung's example shows that this is not possible (without giving up something else) since pure type theory is consistent with EM.
think there is a strong intuition behind the principle (what Dan Doel
and I were getting at), and the fact that it plays an important role
in typechecking suggests that we shouldn't jump to conclusions. I am
not sure that Agda should be conservative over classical mathematics:
it seems there is a fundamental tension between exploiting the full
power of a constructive type theory and upholding the fictions of
classical mathematics. Chung-Kil's paradox shows that you can't
reason classically in Agda just by adding the law of excluded middle
-- okay, so don't do it that way.
Could you explain what you meant by: "Also while we may accept that
extensions of Type Theory may be anticlassical, we should expect thatcore Type Theory is consistent with EM."?
Noam
Agda mailing list
Agda AT lists.chalmers.se
https://lists.chalmers.se/mailman/listinfo/agda
Agda mailing list
- [Coq-Club] [Agda] Agda with excluded middle is inconsistent, Chung Kil Hur
- [Coq-Club] Re: [Agda] Agda with excluded middle is inconsistent,
Thorsten Altenkirch
Noam Zeilberger
Thorsten Altenkirch
Noam Zeilberger
- [Coq-Club] Re: [Agda] Agda with excluded middle is inconsistent, Dan Doel
- [Coq-Club] Re: [Agda] Agda with excluded middle is inconsistent, Thorsten Altenkirch
- [Coq-Club] Re: [Agda] Agda with excluded middle is inconsistent, David Wahlstedt
Noam Zeilberger
- [Coq-Club] Re: [Agda] Agda with excluded middle is inconsistent, Noam Zeilberger
Noam Zeilberger
Andreas Abel
Thorsten Altenkirch
Noam Zeilberger
Thorsten Altenkirch
