- To: "Jeff Terrell" <jeff AT kc.com>, "coq-club AT inria.fr" <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] Is Coq being too conservative?
- Date: Thu, 21 Jan 2010 11:28:01 +0100
- Organization: ProVal
Le Wed, 20 Jan 2010 14:12:30 +0100, Jeff Terrell
<jeff AT kc.com>
a écrit:
Hi,
Is Coq being too conservative in rejecting the definition of f?
Require Import List.
CoInductive A : Set :=
Build_A : list B -> A
with B : Set :=
Build_B : A -> B.
Definition RB := fun a : A => let (RB) := a in RB.
Definition RA := fun b : B => let (RA) := b in RA.
CoInductive X : Set :=
Build_X : list Y -> X
with Y : Set :=
Build_Y : X -> Y.
CoFixpoint f(a : A) : X :=
Build_X (map g (RB a))
with g (b : B) : Y :=
Build_Y (f (RA b)).
Thanks.
Regards,
Jeff.
I think Coq should accept this definition as both f and g are clearly productive;
it is not the case and so it should be reported to the bug-tracking system.
I am not an expert in coinduction, maybe someone can explain us why coq doesn't accept it.
For an even less explicit message error replace f definition with:
let (RB) := a in Build_X (match map g RB with nil => nil | p::q => p::q end)
let (RA) := b in Build_Y (f RA).
or
match a with
| Build_A nil => Build_X nil
| Build_A ((Build_B p)::q) =>
match f (Build_A q) with
| Build_X l => Build_X ((Build_Y (f p))::l)
end
end.
I am not sure the last 2 defs should be accepted; but I don't see reasons why Jeff's one is not.
Problem is even simplier with:
Build_A : list A -> A.
Definition RA := fun b : A => let (RA) := b in RA.
Build_X : list X -> X.
CoFixpoint f (a: A): X :=
Build_X (map f (RA a)).
Cédric AUGER
Univ Paris-Sud, Laboratoire LRI, UMR 8623, F-91405, Orsay
- [Coq-Club] Is Coq being too conservative?, Jeff Terrell
- Re: [Coq-Club] Is Coq being too conservative?, AUGER
- Message not available
- Re: [Type-Based Guardednees Checking] Re: [Coq-Club] Is Coq being too conservative?,
Jeff Terrell
- Re: [Coq-Club] Is Coq being too conservative?, Chris Dams
- Re: [Type-Based Guardednees Checking] Re: [Coq-Club] Is Coq being too conservative?, Adam Chlipala
Jeff Terrell
