Re: [Type-Based Guardednees Checking] Re: [Coq-Club] Is Coq being too conservative?
chronological Thread
- To: "coq-club AT inria.fr" <coq-club AT inria.fr>
- Subject: Re: [Type-Based Guardednees Checking] Re: [Coq-Club] Is Coq being too conservative?
- Date: Fri, 22 Jan 2010 07:57:33 +0000
Dear Andreas & Cedric,
Many thanks for your comments. Unfortunately, this problem is a show stopper for my project. Does anyone know if there's a prototypical implementation of Coq that would allow f to pass the guardedness checker?
Regards,
Jeff.
Andreas Abel wrote:
Hi Jeff,
your counterexample can be simplified to
Require Import List.
CoInductive A : Set :=
| Build_A : list A -> A.
CoInductive X : Set :=
| Build_X : list X -> X.
CoFixpoint f (a : A) : X :=
match a with
| Build_A l => Build_X (map f l)
end.
The Coq guardedness checker does not see that the call to "f" in "map f l" is guarded by constructor Build_X, because it does not take the behavior of map into account. A theoretical solution to this problem has been found and it is called "size types" or "type based termination". So far, only prototypical implementations exist, for instance MiniAgda (see http://www2.tcs.ifi.lmu.de/~abel/miniagda ). In MiniAgda this code passes guardedness checking:
data List (+ A : Set) : Set
fun map : (A : Set) -> (B : Set) -> (f : A -> B) -> List A -> List B
sized codata A : Size -> Set
{ Build_A : (i : Size) -> List (A i) -> A ($ i)
sized codata X : Size -> Set
{ Build_X : (i : Size) -> List (X i) -> X ($ i)
cofun f : (i : Size) -> A i -> X i
{ f .($ i) (Build_A i l) = Build_X _ (map (A _) (X _) (f i) l)
Using sized types, one can see that the r.h.s.
has one guard more ($ i) than the recursive call f i (which has i guards).
Cheers,
Andreas
Jeff Terrell a écrit :
Hi,
Is Coq being too conservative in rejecting the definition of f?
Build_A : list B -> A
with B : Set :=
Build_B : A -> B.
Definition RB := fun a : A => let (RB) := a in RB.
Definition RA := fun b : B => let (RA) := b in RA.
Build_X : list Y -> X
with Y : Set :=
Build_Y : X -> Y.
CoFixpoint f(a : A) : X :=
Build_X (map g (RB a))
with g (b : B) : Y :=
Build_Y (f (RA b)).
Thanks.
Regards,
Jeff.
- [Coq-Club] Is Coq being too conservative?, Jeff Terrell
- Re: [Coq-Club] Is Coq being too conservative?, AUGER
- Message not available
- Re: [Type-Based Guardednees Checking] Re: [Coq-Club] Is Coq being too conservative?, Jeff Terrell
- Re: [Coq-Club] Is Coq being too conservative?, Chris Dams
- Re: [Type-Based Guardednees Checking] Re: [Coq-Club] Is Coq being too conservative?, Adam Chlipala
