- To: Nadeem Abdul Hamid <nadeem AT acm.org>
- Cc: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Defining type of a subset of natural numbers
- Date: Wed, 10 Feb 2010 17:38:58 +0100
Nadeem Abdul Hamid wrote:
I'm working on something where I try to prove properties of functions on some parameterized sets -- i.e.You can use a limited form of proof irrelevance that does not rely on an axiom.
Module Type SIG.
Parameter A : Set.
Parameter B : Set.
Parameter a_eq_dec : forall (a a':A), a = a' \/ a <> a'.
Parameter f : A -> B.
.... properties of f ...
End SIG.
(* followed by some proofs in another functor of SIG that uses properties of f *)
Now, I want to instantiate SIG with an implementation of A and B being a finite subset of natural numbers, e.g.
Definition A := { n:nat | n < 10 }.
Definition B := { n:nat | n < 10 }.
Lemma a_eq_dec : forall (a a':A), a=a' \/ a<>a'.
The problem here is that I can only seem to establish this by introducing the proof_irrelevance axiom.
So the question is: Does anyone have other suggestions for defining concrete instantiations of A and B as finite subsets of the natural numbers, that would allow proof of the a_eq_dec property without introducing proof irrelevance?
Thanks in advance,
nadeem
1/ In standard Coq, it is possible to prove that proofs of equality between boolean values are unique.
2/ you can define a function ltb so that n < 10 <-> ltb n 10 = true
3/ you define A as : { n:nat | ltb n = true}
4/ with this definition of A, you can prove a_eq_dec
For the proof that proofs of equality between booleans, look there:
http://old.nabble.com/Re:-FMaps-and-proof-irrelevance-p25505519.html
Note that in that message, I only rephrase results that were obtained by other researchers.
Yves
- [Coq-Club] Defining type of a subset of natural numbers, Nadeem Abdul Hamid
- Re: [Coq-Club] Defining type of a subset of natural numbers, Carsten Varming
- Re: [Coq-Club] Defining type of a subset of natural numbers, Adam Chlipala
- Re: [Coq-Club] Defining type of a subset of natural numbers, Yves Bertot
- Re: [Coq-Club] Defining type of a subset of natural numbers, Adam Koprowski
- Re: [Coq-Club] Defining type of a subset of natural numbers, Hugo Herbelin
