coq-club - Re: [Coq-Club] Defining type of a subset of natural numbers
chronological Thread
  • To: Nadeem Abdul Hamid <nadeem AT acm.org>
  • Cc: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] Defining type of a subset of natural numbers
  • Date: Wed, 10 Feb 2010 11:17:22 -0500 (EST)
This has been dealt with in ssreflect. They make < into a function nat -> nat -> bool, and thus get proof irrelevance for free. They have also packaged this kind of reasoning very nicely in suitable structures. They have even defined the finite type you need and put some work into showing suitable lemmas you may need.
Carsten
On Wed, 10 Feb 2010, Nadeem Abdul Hamid wrote:
I'm working on something where I try to prove properties of functions on some parameterized sets -- i.e.
Module Type SIG.
Parameter A : Set.
Parameter B : Set.
Parameter a_eq_dec : forall (a a':A), a = a' \/ a <> a'.
Parameter f : A -> B.
.... properties of f ...
End SIG.
(* followed by some proofs in another functor of SIG that uses properties of f *)
Now, I want to instantiate SIG with an implementation of A and B being a finite subset of natural numbers, e.g.
Definition A := { n:nat | n < 10 }.
Definition B := { n:nat | n < 10 }.
Lemma a_eq_dec : forall (a a':A), a=a' \/ a<>a'.
The problem here is that I can only seem to establish this by introducing the proof_irrelevance axiom.
So the question is: Does anyone have other suggestions for defining concrete instantiations of A and B as finite subsets of the natural numbers, that would allow proof of the a_eq_dec property without introducing proof irrelevance?
Thanks in advance,
nadeem
